Lifter preload
Old Aug 29, 2018 | 10:11 AM
CamaroSS30thAnn's Avatar
Lifter preload
Im running a 234/244 598/614 cam
comp 850 lifters
comp 1.6rr
7/16 rocker studs
Cars up and running but have a question in preload for the comp 850 lifters. I seem to get an awful lot of noise.
What would be a good preload? Right now ik at 1/4 after 0 lash.
comp recommends half to 3/4 from what ive read but there is a lot of conflict on this.
Just looking for opinion and anyone who runs similar set ups.
Old Aug 29, 2018 | 10:21 AM
Chimera96's Avatar
Re: Lifter preload
FWIW I started with a 1/4 turn with my 850's on my 383 H/C build. To me they were a little noisy. Went to 1/2 turn and they were better and then I went between 1/2 & 3/4 turn and am happy with the results. Motor now has about 40k mi on it since the lash at that setting
Of course starting from what I feel is zero lash and what you or others may will be different. I use the "no more up/down movement" for zero vs the "spin until you feel a slight drag" method of finding zero lash. IMHO the later method you blew by zero at least a 1/4 turn ago if not more.
my cam is smaller lift than yours .570/.565
Old Aug 29, 2018 | 10:43 AM
Re: Lifter preload
So your saying its better to do the up down movement?
Old Aug 29, 2018 | 01:01 PM
Re: Lifter preload
The only thing im afraid of is having them to tight and causing issue.
Old Aug 29, 2018 | 02:33 PM
Chimera96's Avatar
Re: Lifter preload
Well IMHO I use up/down method. When there is no more movement of PR "up/down" as I finger tight the poly (read very gently finger tight) than that is "zero" lash and from there you go with whatever "pre-load" you want. GM service book says 1 to 1 1/2 turns. Some feel with high lift cams and high (above 5700) rpm shifts than a lower pre-load (1/4 to 3/4 turn) is better
For me I found just a little over 1/2 turn (about 3/4) works well for me. 1/4 turn was OK in terms of performance but was just a little noisy, especially after car had warmed up so I went 1/2 then decided just a little more work best for me in terms of noise and high RPM use is solid
Lifters, just like any other part in a motor, is a wear item especially with high lift cams and high RPM use so they can "fatigue" and if they get noisy even after repeated lash than changing them would be required. Stock lifters in a untouched stock motor kept in good operating condition can last, and should, the lifetime of the motor.
Old Aug 29, 2018 | 03:00 PM
Re: Lifter preload
Thank you. Yes i understand.
A quarter turn is just annoyingly loud especially when running hot. So i think i may do a half turn and se how i like it.
ill use the up down method.
Basically make sure the pistons at TDC. Tighten the rocker until up/down no longer occurs then preload half a turn and lock.
ill do it warm also.
Old Aug 29, 2018 | 03:22 PM
STSturboLT1's Avatar
Re: Lifter preload
I went a full turn with my setup and have no complaints about valvetrain noise.
Old Aug 29, 2018 | 09:26 PM
Re: Lifter preload
I think im gonna try half turn for now. And go from there.
ive got the composite valvecovers now so i assume that os gonna lessen the noise.
Old Aug 29, 2018 | 10:42 PM
Chimera96's Avatar
Re: Lifter preload
The composite covers that were on the LT4 were to help reduce the noise of the RR. LT4 knock "module" was also less sensitive to the sound of RR
Old Aug 29, 2018 | 10:58 PM
Re: Lifter preload
yessir they are lt4, no longer have an lt4 km, im 24x
Meen95z
May 23, 2010 02:13 PM
Casey_SS
May 4, 2007 01:13 AM
94zrag
Nov 28, 2005 02:48 PM
Munson
Mar 7, 2005 06:54 AM
Type_O_Negative_1320
Mar 3, 2004 06:41 PM
