simple valve adjustment question.
Old Nov 27, 2005 | 06:58 PM
94zrag's Avatar
How do you know how much preload to put on the lifters? With all the searching i've done, the only answers i could come up with are between 1/16th and a full turn. But how do you know if they're too loose or too tight? I know if they're too loose they'll make alot of noise, but mine seem to sound the same between the min. and max. adjustments. Any thoughts?
Old Nov 27, 2005 | 07:08 PM
SStrokerAce's Avatar
Re: simple valve adjustment question.
The least amount of preload you need to make them quiet is one way to look at it. Otherwise as close to zero preload/lash as possible.
Bret
Old Nov 27, 2005 | 07:11 PM
Quickshotkimber's Avatar
I used to go 1/4 turn with the stockers and it kept the valvetrain pretty quiet. With the comp rs I try to keep it as close to zero lash as possible.
Old Nov 27, 2005 | 07:17 PM
OBE1 95Z28's Avatar
Depends on the lifters. The Comp Cams R lifters are very sensitive to preload and require very little (1/16 - 1/8 turn). Stock lifters are between 1/2 - 1 turn.
Old Nov 27, 2005 | 08:39 PM
respectirocz's Avatar
how do you determine when u have zero lash? when the pushrod no longer moves up/down or when it no longer spins freely?
Old Nov 27, 2005 | 09:01 PM
silverz28's Avatar
I do mine when the push rod no longer spins freely. You can't go by the up and down. You will be able to feel it when the push rod starts dragging.
Old Nov 27, 2005 | 10:05 PM
1racerdude's Avatar
Go here and look up the procedure ya will learn a lot.
http://shbox.com/page/index.html
Old Nov 28, 2005 | 02:48 PM
OBE1 95Z28's Avatar
The key word is "starts" dragging. If you tighten it down until the pushrod doesn't spin at all, you're already past zero lash. Zero lash is the point where the parts are line to line, no play up and down. Once to start to push down on the pushrod past this line to line condition, you are applying preload. The trick is that hydraulic lifters have a spring in them that can be soft so it's a touch thing to know that you're not moving the spring when your hunting for zero lash.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
sseeya
Apr 9, 2015 06:38 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
