Caddy Racing Lifters?
Old May 13, 2010 | 11:27 PM
Meen95z's Avatar
Exclamation Caddy Racing Lifters?
I have a set of caddy racing lifters on my lt4 with comp pro mag roller rockers. I adjusted them 0 lash and 1 turn. They are extremely noisy and I was wondering if they are all this noisy or is the preload off? I ran these last year and thought they were quieter than what they are.. Any info besides buy new lifters is appreciated. Thanks
Old May 14, 2010 | 03:11 AM
Sk8phreak88's Avatar
You did one full turn after 0 lash? That could be it right there, usually its 1/4-3/4- on the max. I do 1/2 turn after zero lash. :thup:
Old May 14, 2010 | 01:00 PM
Meen95z's Avatar
Well I started at 1/2 a turn and it was still noisy. I have 3in xpipe dumped with longtubes and I can hear the ticking over my car when im driving with the windows down. Would to much preload cause them to be noisy?
Old May 14, 2010 | 03:27 PM
Stl94LT1's Avatar
A few other things can also contibute to valvetrain noise, valve springs, agressive ramps on the camshaft, and the Comp Pro Magnums are noisy.
Old May 14, 2010 | 03:32 PM
wrd1972's Avatar
I agree. Try 1.5 TPZL.
Old May 14, 2010 | 04:22 PM
96azhawk's Avatar
They key point is that the Caddy lifters apparently require quite a bit of preload compared to other lifters even the LS7 ones.
I am running the Caddy lifters and am at 1TPZL now.
Old May 14, 2010 | 04:23 PM
dangalla's Avatar
most people settle around 1/4 past 0 lash
something else is causing your issue, but being set at 1 turn i would think will also cause a problem. what other components are you using
Old May 14, 2010 | 11:56 PM
Meen95z's Avatar
I have 7/16 arp studs, trickflow guide plates, patroit gold extreme dual springs, le custom grind cam, comp pro mag 1.6 roller rockers nsa, caddy racing lifters..
not sure what other components you wanna know about.
Old May 15, 2010 | 07:58 AM
Stl94LT1's Avatar
I have a similar setup with the stock lifters, and my valvetrain is noisy also.
Old May 16, 2010 | 02:32 AM
Meen95z's Avatar
I turned the to 1/2 turn and not as bad at a idle, but when it gets up around 3k and above they start getting really noisy. Will this cause valvetrain damage or is it just gonna be noisy?
Old May 17, 2010 | 11:31 AM
marshall93z's Avatar
Friend of mine had them and it sounded like CONSTANT piston slap! Never went away until he changed lifters...
Old May 20, 2010 | 12:24 AM
Meen95z's Avatar
I have tried 1/4 turn to 1-1/4 turn past 0 lash and still noisy on the drivers side. Not to bad when its cold, but when it warms up it gets bad. Sounds like a bad exhaust leak when im driving it. Bad lifters? I ran them last year and they was fine, just re-installed them..
Old May 21, 2010 | 10:42 PM
96lt4vette's Avatar
I must be the exception - I have caddy lifters and run them at 1/8 turn. No problem with noise.
Old May 22, 2010 | 04:58 AM
camaro1fastz28's Avatar
put rotella t 15w 40 and u will not hear them
Old May 22, 2010 | 08:46 AM
bw_hunter's Avatar
You're not the exception...I'm at 1/8 turn past zero lash as well. I run Crane Gold roller rockers, though.
