leaking fluids
leaking fluids
When i park my car in the garage and back it out, the last 5 or 6 days theres a small puddle of tranny fluid (smells like tranny fluid anyway) not very big at all, but still its there. Any suggestions where it could be leaking from? thanks.
I have the very same problem in my 1994 Trans Am. I was told in the Drivetrain section that it is the rear seal on the tranny where the driveshaft meets the tailshaft. I will let you know after I narrow down the leak this weekend.
your leak
I own 1997 30th Anniverary Camaro SS......i have the same problem...im not sure about your problem but its the tailshaft seal where the driveshaft bolts to the tranny and also my pinion seal where the drivehaft bolts to the rearend....already beng fixed
97WS6SCharged.......hey man thanks.....im not really sure i was planning on doing it over the winter while the cars away to get it set for summer....thanks for the info ill have to get that checked out........anyways im fairly new this is like my 2nd post if there snythingi need to know about this site is appreciate some info
Noct
Jul 14, 2015 01:18 AM
