leaking fluids
Old Dec 11, 2003 | 10:58 PM
TheOutlaw's Avatar
leaking fluids
When i park my car in the garage and back it out, the last 5 or 6 days theres a small puddle of tranny fluid (smells like tranny fluid anyway) not very big at all, but still its there. Any suggestions where it could be leaking from? thanks.
Old Dec 11, 2003 | 10:59 PM
texasTA's Avatar
I have the very same problem in my 1994 Trans Am. I was told in the Drivetrain section that it is the rear seal on the tranny where the driveshaft meets the tailshaft. I will let you know after I narrow down the leak this weekend.
Old Dec 12, 2003 | 12:01 AM
VegasZ's Avatar
Retorque your pan bolts and see if that takes care of the leak. Did with mine.
Old Dec 12, 2003 | 12:17 AM
97WS6SCharged's Avatar
Most common places for the slush boxes to leak are the front seal, the rear seal, and the pan. Where is the puddle in relation to the transmission?
Old Dec 12, 2003 | 12:55 AM
TheOutlaw's Avatar
to be honest, i dunno where its leaking, just in the vicinity of the trans/ possible rear engine area, but i will check the pan bolts, btw its a 1994 TA.. thanks to everyone!
Old Dec 12, 2003 | 01:22 AM
CamaroSS30thAnn's Avatar
your leak
I own 1997 30th Anniverary Camaro SS......i have the same problem...im not sure about your problem but its the tailshaft seal where the driveshaft bolts to the tranny and also my pinion seal where the drivehaft bolts to the rearend....already beng fixed
Old Dec 12, 2003 | 01:34 AM
CamaroSS30thAnn, did you have a bad drive shaft or something? You might want to look into having the DS balanced and see if you need new Ujoints.
Old Dec 12, 2003 | 01:46 AM
97WS6SCharged.......hey man thanks.....im not really sure i was planning on doing it over the winter while the cars away to get it set for summer....thanks for the info ill have to get that checked out........anyways im fairly new this is like my 2nd post if there snythingi need to know about this site is appreciate some info
PCLZ28
Dec 24, 2015 05:19 PM
pimpen1024
Aug 19, 2015 08:36 PM
MikeWhitener
Aug 2, 2015 06:17 PM
dolfan324
Jul 17, 2015 10:34 PM
Noct
Jul 14, 2015 01:18 AM
