LE2/GM847 Cam Finally Running!!
Old Jul 15, 2005 | 01:45 PM
  #16
ZMAN Z28's Avatar
Re: LE2/GM847 Cam Finally Running!!
477 every 6 months with 250 deductable, full coverage. I don't want to know what you think of me. Sorry for the hijack.
Z
Old Jul 15, 2005 | 03:05 PM
  #17
new_z's Avatar
hmm.. I only pay 300 for 6 months with full coverage 50 deduct. for comprehensive and 250 deduct for collision, course I don't have to worry about moose and other "larger" animals
that makes me depressed!!!! 20 tickets. 260/month. im broke
im doing a similar setup once i getta out iraq! (heads and a gm 847) i heard it sounds like a 9 second drag car on open headers! cant wait! and send me a like to the vid please. these gov computers suck and EVERYTHING IS BLOCKED !!!
Old Jul 15, 2005 | 03:11 PM
  #18
FastZinTennessee's Avatar
Originally Posted by Silvershark
Anyhow, I tried to take the car out tonight for its first test run... It almost immediatly overheated like a block away from my house... Is this even possible???
I have an electric water pump, the black wire is hot and the blue wire is ground.
It's possible if you have the ground and +12v wires hooked up backwards I decided to ditch the electric pump a while ago after some problems. I'm not going to trust my new $4k+ motor to one of those pieces of s***.
Old Jul 15, 2005 | 06:54 PM
  #19
ZMAN Z28's Avatar
Not all of our women in South Dakota are moose. We have a couple skinny ones.
ZMAN
Old Jul 15, 2005 | 07:09 PM
  #20
Silvershark's Avatar
So on the CSI which wire is hot and which wire is ground?
I have a blue and a black wire coming from the pump.
Thanks guys.
Old Jul 15, 2005 | 07:16 PM
  #21
http://ken.lowrance.com/Projects/CSI...mp/Default.htm
Looking at this wiring diagram I am assuming the blue is the hot and the black is the ground...
Old Jul 15, 2005 | 07:43 PM
  #22
slverbullet's Avatar
black is typically the ground wire in most scenarios. i would assume the black is ground. try it and see what happens. you wont be any worse off than you are now. make sure to bleed the system again since you'll be hooking the pump up the right way this time. and you definitely should be able to hear the pump if the key is in the "on" position without the motor running.
Old Jul 15, 2005 | 08:14 PM
  #23
ZMAN Z28's Avatar
Since it's an electric motor with only 2 wires. One has to go to ground and the other has to go to your power source. If you switch the wires around, you will change the direction the electrons flow, which in turn the electricity will flow the other way. But I would hook the black to ground.
ZMAN
Old Jul 15, 2005 | 08:22 PM
  #24
Ok, Black was used as ground, blue as hot.
Using freescan my engine temp stayed around 180-200. My fans kicked on at 180 degrees F and my low coolant light came on. So I imagine the flow is now correct and it is cyling it through the block which in turn is making the low coolant light come on.
However, my gauge in my cluster shows that the engine temp is almost red, which I would assume to be like 240 degrees?? Which one is correct the gauge in the cluster or the ECU temp that it is recording to my laptop via Freescan.
Old Jul 15, 2005 | 09:24 PM
  #25
ZMAN Z28's Avatar
I'd change out the sensor on the drivers side head. I am pretty sure this is the coolant temp sensor. Can anyone help verify this? They are around 12 dollars at www.partsamerica.com.
ZMAN
Old Jul 15, 2005 | 09:50 PM
  #26
94zgreenmachine's Avatar
ZMAN
yup, drivers side head sensor is for the gauge and the sensor in the water pump is for the pcm to read.
Old Jul 16, 2005 | 03:49 AM
  #27
Ok, figured out the problem... Needed to burp the coolant system some more and the gauge on the cluster is now fine. The ECU and the cluster gauge now match, within 5 or so degrees.
It got late here though so I didnt have a full time period to test the car out and make sure everything was running as planned.
I will take her for a spin tomorrow if everything looks good and go from there.
Thanks guys!
Old Jul 16, 2005 | 05:56 AM
  #28
They can be stubborn at times!
Old Jul 16, 2005 | 11:31 AM
  #29
Thanks guys!
k, good luck and have fun!
Amshnock
14
Jan 18, 2015 11:47 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
ChrisFrez
Dec 7, 2014 06:01 PM
Queens94z28
Nov 20, 2014 06:03 PM
