LE2/GM847 Cam Finally Running!!
Re: LE2/GM847 Cam Finally Running!!
hmm.. I only pay 300 for 6 months with full coverage 50 deduct. for comprehensive and 250 deduct for collision, course I don't have to worry about moose and other "larger" animals
that makes me depressed!!!! 20 tickets. 260/month. im broke
im doing a similar setup once i getta out iraq! (heads and a gm 847) i heard it sounds like a 9 second drag car on open headers! cant wait! and send me a like to the vid please. these gov computers suck and EVERYTHING IS BLOCKED !!!
Originally Posted by Silvershark
Anyhow, I tried to take the car out tonight for its first test run... It almost immediatly overheated like a block away from my house... Is this even possible???
I have an electric water pump, the black wire is hot and the blue wire is ground.
I decided to ditch the electric pump a while ago after some problems. I'm not going to trust my new $4k+ motor to one of those pieces of s***.
ZMAN
http://ken.lowrance.com/Projects/CSI...mp/Default.htm
Looking at this wiring diagram I am assuming the blue is the hot and the black is the ground...
Since it's an electric motor with only 2 wires. One has to go to ground and the other has to go to your power source. If you switch the wires around, you will change the direction the electrons flow, which in turn the electricity will flow the other way. But I would hook the black to ground.
ZMAN
ZMAN
Ok, Black was used as ground, blue as hot.
Using freescan my engine temp stayed around 180-200. My fans kicked on at 180 degrees F and my low coolant light came on. So I imagine the flow is now correct and it is cyling it through the block which in turn is making the low coolant light come on.
However, my gauge in my cluster shows that the engine temp is almost red, which I would assume to be like 240 degrees?? Which one is correct the gauge in the cluster or the ECU temp that it is recording to my laptop via Freescan.
I'd change out the sensor on the drivers side head. I am pretty sure this is the coolant temp sensor. Can anyone help verify this? They are around 12 dollars at www.partsamerica.com.
ZMAN
ZMAN
ZMAN
ZMAN
Ok, figured out the problem... Needed to burp the coolant system some more and the gauge on the cluster is now fine. The ECU and the cluster gauge now match, within 5 or so degrees.
It got late here though so I didnt have a full time period to test the car out and make sure everything was running as planned.
I will take her for a spin tomorrow if everything looks good and go from there.
Thanks guys!
Thanks guys!
Thanks guys!
Thanks guys!
ChrisFrez
Dec 7, 2014 06:01 PM
I don't want to know what you think of me. Sorry for the hijack.
