Le2 Dyno Results
Old Dec 19, 2005 | 03:35 PM
  #61
1racerdude's Avatar
Re: Le2 Dyno Results
I wish I could have afforded a set for this 383. The kit from Burns is $1500.00 and it would have cost $800.00 to have them fitted made and welded. Maybe after I get it running and save up(get an engine to build) I can get a set. I think they will improve it's performance. For now the 4/1 modified will do.
Old Dec 19, 2005 | 04:02 PM
  #62
SStrokerAce's Avatar
Originally Posted by 1racerdude
I bet I know-- Carbon Fiber Crank-- huh???
Hey,is it snowing up there yet? Sleeting and raining here and 53*.
Well they have weights on everything now, so getting the intertia lower is definately going to help.
Bret
Old Dec 19, 2005 | 06:40 PM
  #63
96capricemgr's Avatar
Originally Posted by Mindgame
Thou dost deal a great deal in assumption Dwayne. You know what they say about assumption right?
BTW, what are the fastest b-bodies out there running as far as headers go?
I'm not going to knock a tri-y. The headers I'm using now are a 4-2-1, just with much longer primaries than your typical "Thorley" looking try-y.
-Mindgame
This is in reply to Cheston's post too.
But since when does what a dedicated race cars runs dictate what the rest of us should run? What is right on those car may or may not be good for a street car, and again he might pick up time with the quads but I think this still shows how well a "small tube" header can work even when it "shouldn't".
Old Dec 19, 2005 | 07:15 PM
  #64
Dwayne,
The point is relative to the HP levels of the cars. The more RPM and HP you are trying to push thru a header the larger it has to be. Mindgame has a whole ton of experince with street and race cars. Where race cars are well below 9 sec range for him, I'm guessing maybe 7's NA at least thats where Comp Elm cars run.
The big difference that is going to happen here with a larger diameter tubing size will be a shift in the TQ curve up 250rpm with not much change in TQ at stall speed.
He had some great results with those headers, and hell a tri-y header in a larger diameter tube would be the way to go IMHO.
Bret
Old Dec 19, 2005 | 08:27 PM
  #65
Mindgame's Avatar
I never said what "they" run should sway you did I?
I just asked the question out of curiosity, sheesh! These b-body guys are a touchy bunch.
Bret is right, at some point your "good" 1-5/8" header is going to cost you power. Pumping losses and all that jazz. I'd be very interested in seeing a test though.... this 1-5/8" tri-y swapped for a good 1-3/4" on a 450 fwhp LT1.
As for the Anderson Pro-Stock ref... try finding a guy these days who doesn't run a 4-2-1 header in PS. I think they're all 4-2-1 now.
BTW, you can find very high quality merge collectors and stainless tubing from SDP Products. The prices are a touch easier on the pocket than Burns.
-Mindgame
Old Dec 19, 2005 | 11:24 PM
  #66
NightTrain66's Avatar
I would honestly be amazed if the car did not pick up from going to a 1 3/4 header. I agree with what they are saying about the 4-2-1 headert being the better design but I think the 1 3/4 header instead of the 1 5/8 along with possibly larger collector would make the car run better even though they are a 4-1 header.
As I stated earlier, I do not claim to know it all and I am willing to learn. If Ken installs the 1 3/4 headers and runs a tenth faster, the same E.T., or a tenth slower, we will all know. Until I see this test, I will have to guess that the car will be faster.
I can see the 1 5/8 headers being the best choice on an Impala with 3.08 gears, stock coinverter and a GM 845 cam with a 6000 RPM shift point and the 1 3/4 headers being better for Kens set up. Kens set up is a lil different than most Impalas out there and I think the bigger headers are the better choice for HIS set up.
Lloyd Elliott
972-617-5671
Eportworks.com
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
HAWG
Sep 25, 2015 11:41 AM
Daluchman1974
Sep 11, 2015 06:12 AM
