Le2 Dyno Results
Old Dec 16, 2005 | 07:34 PM
ken9c1SS's Avatar
Le2 Dyno Results
This is in my 95 impala ss with 3.73 gears and a edge 3500 stall.
438 hp 419lbs of torque with the converter locked
423 hp 407lbs of torque with the converter unlocked.
intake also ported, this is on a 383.
all i can say is
Old Dec 16, 2005 | 07:42 PM
DiabloGT's Avatar
Re: Le2 Dyno Results
is this rear wheel or flywheel? and how can you lock and unlock a torque convertor, like what do you have to do? and does anyone know how this effects hp?
thanks
Old Dec 16, 2005 | 07:44 PM
AdioSS's Avatar
West South Central Moderator
Good job Ken!
SStrokerAce's Avatar
Rear Wheel
Lloyd called me earlier and told me about it.... oh and the "this cam ain't gonna work" bs from the dyno guys BEFORE the dyno pulls. Guess he still doesn't think it's going to work.
GOOD NUMBERS!
Bret
Old Dec 16, 2005 | 08:05 PM
jkipp84's Avatar
NICE numbers dude!
Old Dec 16, 2005 | 08:28 PM
MachinistOne's Avatar
NICE numbers!
Is that cam emissions friendly Bret?
Old Dec 16, 2005 | 08:32 PM
emissions? what is that?
Old Dec 16, 2005 | 09:20 PM
Honda Hunter's Avatar
I would like to know as well. I also wouldve thought the numbers wouldve been more space apart locked unlocked. Sweet numbers.
Old Dec 16, 2005 | 09:27 PM
89385formula's Avatar
Very impressive! Congrats.
Old Dec 16, 2005 | 09:40 PM
Cmr0z28's Avatar
wow. who tuned it?
Old Dec 16, 2005 | 10:02 PM
NightTrain66's Avatar
Some very bad *** #'s thru an A4 and stall. All of that with that small of a cam is amazing. TONS of TQ at every RPM and being on a 383, the peak HP #'s are in by 6100 RPM. I have not seen the graph yet but it is probably over 400 RWHP by 5300 RPM or maybe even sooner.
I am sure it is fun to drive with the TQ that this small cam makes.
Your 4400 LB weight is gonna definitey hurt track times but as long as you can get the car to hook and get a 1.6X 60 ft, you should be able to run an 11.70 at 115 MPH. Remember, this is a HEAVY Impala, not a 3400 lb F body.
Lloyd Elliott
972-617-5671
Eportworks.com
Old Dec 16, 2005 | 10:08 PM
ChrisUlrich's Avatar
Damn... I know this is confidential stuff but... can you PM me the info on the cam and head numbers? I'm a Lloyd Elliot customer, but i'm just very curious to see what kind of numbers my VR 383 LE3 puts out through a M6 and 10 bolt.
Old Dec 16, 2005 | 11:00 PM
The cam is alot smaller than most run in their 350/355 much less a 383.The cam is smaller than a GM 847 and they are my LE2 heads (LT1 castings with 2.00/1.56 valves). I think they flowed about 275/195 at .600 lift.
Chris, your cam is about 8 degrees larger intake and exhaust. This Impy needs all the TQ it can get to get the thing moving. A lighter F body or Vette can use a larger cam and make more HP since these cars are easier to accelerate.
Lloyd Elliott
972-617-5671
Eportworks.com
Old Dec 16, 2005 | 11:26 PM
Cmr0z28's Avatar
SAE or STD #s?
Old Dec 16, 2005 | 11:39 PM
Dynojet?
Again - very impressive.
