LE1e and PCMforless E-test
Old Dec 2, 2006 | 01:50 PM
Another Red Z's Avatar
Thumbs up LE1e and PCMforless E-test
For those that curious as to wether or not you will pass with the LE1e cam it is all good . I have the LE 1.5e package which is the emission cam and LE2 heads.I also have a SLP shorties with a cat and the rest of the emission crap hooked up.The car just has the "starter tune" from PCM for less.I have yet to begin to tweak it .
HC CO% NOx
L 53 .28 614
A 53 .01 146
I would say that with a little tweaking this could become cleaner if limits are lower than CT standards.
Without giving the specs away this cam is right in the middle of a Hot cam and CC305 duration wise.
Old Dec 2, 2006 | 01:57 PM
SS MPSTR's Avatar
I passed California's test with the CC305 a few years ago with flying colors.
Old Dec 2, 2006 | 02:08 PM
Z-RATED94's Avatar
Mike, any dyno #'s to go with your set-up? And congrats on passing the emissions test. I know that even though you think it will pass, it's always a pleasure when your done with it and driving away knowing you have 2 more years before the next one.
Old Dec 2, 2006 | 02:49 PM
SStrokerAce's Avatar
Mike,
What were your limits in those tests?
Bret
Old Dec 2, 2006 | 03:25 PM
The limits are
HC CO% NOx
53 .28 614
I had the car dynoed but was running way to lean. It put down 336 hp at 5800 and 323 ft-lbs at 5000.This is with a 13.9 AFR.We tried some things in the tune and it help a little , but I think the fuel pump is done. I will have to wait and pick up the Racetronixs kit .
95craz28
11
Sep 12, 2015 07:47 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
Chris`s85Z28
3rd Gen / L98 Engine Tech
Nov 27, 2002 06:34 PM
curly
Nov 3, 2002 11:26 PM
ROCKY
Oct 4, 2002 10:51 PM
