Did I get the right gasket kit?
Old Nov 4, 2006 | 07:50 PM
droptop z's Avatar
I've been searching all day and I finally found a timing cover gasket kit. I got the FelPro kit, p/n TCS 45956, I hope that this is the one I need. Could anyone let me know if this is the right p/n before I start tearing into it in the morning? I know it'll be just my luck that it won't be the right one. It just seems like the Opti seal looks too big.
Old Nov 4, 2006 | 07:55 PM
Bawls's Avatar
Timing Cover Gasket for a
1995 Pontiac Firebird
FELPRO TCS45956
Yup thats the right one.
Old Nov 4, 2006 | 08:09 PM
droptop z's Avatar
Thank you.
Old Nov 5, 2006 | 07:03 AM
The Engineer's Avatar
That kits is the one for the later model LT vented opti 96-97. Does your 95 have the vented opti?
WD
http://www.cardomain.com/ride/2189634
Old Nov 5, 2006 | 07:12 AM
95LT1conv's Avatar
yes 95 and later have the vented opti
Old Dec 1, 2006 | 12:13 PM
jeepbeast's Avatar
wondering what those two little o rings are? where do they go?
Old Dec 1, 2006 | 02:05 PM
RUDEDOG's Avatar
They go on the waterpump driveshaft.
Old Dec 1, 2006 | 02:10 PM
Javier97Z28's Avatar
Moderator
I believe they go on the opti driveshaft.....
Old Dec 1, 2006 | 09:10 PM
bingo's Avatar
I saw all these gaskets just last week. The O rings go on the part of the opti that goes into the camshaft. I put a little lube on mine to help the opti go on a little easier.
Old Dec 1, 2006 | 11:03 PM
RUDEDOG's Avatar
The opti does not go into the cam on a 95.
Old Dec 2, 2006 | 07:09 AM
bingo's Avatar
I disagree. The nub on the back of the opti goes through the cam gear and rests in the end of the camshaft.
Old Dec 2, 2006 | 07:20 AM
Dave89IROC's Avatar
yes it does
Old Dec 2, 2006 | 10:09 AM
Moderator
You sure you've done this stuff before? Don't sound like it...
As mentioned, the opti's nub pops into the cam through the timing gear.
Old Dec 2, 2006 | 12:49 PM
RUDEDOG's Avatar
What I meant was the dowel pin on the cam drives the opti. It does not have a spline drive like the unvented type. It does not go (into the cam gear).
Old Dec 2, 2006 | 04:01 PM
Dave89IROC's Avatar
the vented optis have a shaft about an inch long that goes THROUGH the cam gear, and into the front of the cam, those O-rings go on that shaft, to provide stabalization for the opti shaft
