LE1e and PCMforless E-test
For those that curious as to wether or not you will pass with the LE1e cam it is all good . I have the LE 1.5e package which is the emission cam and LE2 heads.I also have a SLP shorties with a cat and the rest of the emission crap hooked up.The car just has the "starter tune" from PCM for less.I have yet to begin to tweak it .
HC CO% NOx
L 53 .28 614
A 53 .01 146
I would say that with a little tweaking this could become cleaner if limits are lower than CT standards.
Without giving the specs away this cam is right in the middle of a Hot cam and CC305 duration wise.
HC CO% NOx
L 53 .28 614
A 53 .01 146
Mike, any dyno #'s to go with your set-up? And congrats on passing the emissions test. I know that even though you think it will pass, it's always a pleasure when your done with it and driving away knowing you have 2 more years before the next one.
The limits are
HC CO% NOx
53 .28 614
I had the car dynoed but was running way to lean. It put down 336 hp at 5800 and 323 ft-lbs at 5000.This is with a 13.9 AFR.We tried some things in the tune and it help a little , but I think the fuel pump is done. I will have to wait and pick up the Racetronixs kit .
HC CO% NOx
53 .28 614
curly
Nov 3, 2002 11:26 PM
