LE 2.2 idle MAP
Old May 9, 2010 | 02:48 PM
nittanylionlt1's Avatar
LE 2.2 idle MAP
What kind of MAP are you pulling @idle.
I'm idling around 900RPM @ 70 kpa.
Old May 9, 2010 | 02:55 PM
rskrause's Avatar
Moderator
70 kPa ~= 7in Hg vacuum. W/O knowing your cam specs, hjard to say if it's eunexpected, but if you have a decent cam with a relatively narrow LSA, it's about in the expected range. Mine is 10-11" @ 750rpm with 214/224 on a 114lsa with a 383.
Rich
Old May 9, 2010 | 03:18 PM
I've reviewed data logs from several engines with the LE2/LE3 cams, and they do not pull a lot of vacuum. You're probably a little on the high side for MAP kPa for a 2.2, but its not that different from what I've seen - high enough to set a code for high MAP/low vacuum at idle. Seems to be a common issue.
Old May 9, 2010 | 03:46 PM
Thanks. What KPA does that code set at?
Old May 9, 2010 | 04:23 PM
68kPA for more than 5 seconds, with throttle 4% or less, in OBD-I.
Old May 10, 2010 | 03:09 PM
johnnyb's Avatar
FWIW, on my le3.2 im pulling right around 7.5 - 8"vac at idle on a 107lsa
Nayr
Mar 3, 2023 08:34 PM
Double aught
Oct 2, 2015 11:29 PM
tdigger9899
Sep 7, 2015 10:56 AM
FredM
Aug 14, 2015 01:49 PM
Boss002
Jul 24, 2015 10:47 AM
