LCA's without brackets?
Old May 9, 2003 | 10:42 PM
Like My Taillights?'s Avatar
Will LCA's without the relocation brackets make a difference? I'm looking to add a little traction as my next mod. I need to lower my 60ft time. I don't want drag radials just yet . Oh, and my car isn't lowered either. Thanks
Old May 9, 2003 | 10:53 PM
FTC's Avatar
FTC
you will be very pleased with relocation brackets. they make a huge difference. i personally wouldnt pass on these if i were lookin for more traction
Old May 9, 2003 | 11:23 PM
Draco's Avatar
new control arms with stiffer bushings will reduce wheel hop and increase traction. LCA brackets will help as well if you use them, but either of these items can be used seperately for improcement.
Just beware of Poly bushings (on both ends) if you want to autoX/road race your car.
Old May 10, 2003 | 10:00 AM
Thanks for the replies. Is BMR a good product? Also, I was thinking of getting the bolt in brackets, are these as good as the weld in type? Thanks
Old May 10, 2003 | 03:41 PM
Anyone?
Old May 10, 2003 | 03:53 PM
Bud M's Avatar
BMR LCAs are good and will improve your launch, but I've read that BMR's relo brackets could be better. I thought the brackets were only helpful on lowered cars to get the LCA geometry back where it should be.
Old May 11, 2003 | 09:21 PM
Draco's Avatar
LCA brackets help on stock ride height cars also. When you launch hard, the rear will squat, throwing off the geometry. This is why relocation brackets are also called anti-squat brackets.
I used the BMR bolt-in brackets and they stood up just fine to my old heads/cam/street twin setup.
Old May 11, 2003 | 10:43 PM
JWBerk94Z's Avatar
LCA's are great. I got a set of MAC LCA's and torque arm and the car responded well. I still need tires so I can't speak for traction a lot. The main thing that I noticed was that my car shoots straight now. It had a tendency to shoot left or right when I launched it or hit second gear. Now it has straightened out, unless I nudge the wheel
I think you will be happy with LCA's. I don't have any input on the brackets, but from the previous posts maybe I should get some.
Old May 11, 2003 | 10:54 PM
norcalstreet's Avatar
When getting lower control arms it's always best to get the relocation brackets as well. The relocation brackets plant your tires on the road much better.
I ran with some boxed lower control arms for about six months before adding relocation brackets (weld-in type) and I could feel a decent improvement. My Z28 is lowered as well but as others say they're even helpful on non-lowered cars.
I have both boxed and tubular in stock and ready to ship if you'd like to order some. Simply visit my site at http://www.norcalstreet.com. If you order online just mention which color you want. I have red and black in stock.
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
War Engine
Sep 18, 2015 07:28 PM
Henson071
Sep 18, 2015 04:01 PM
Boss002
Jul 24, 2015 10:47 AM
