Lca ????
Lca ????
With the setup that I have now would it be worth getting new LCA's?
Also if I did I should see a decrease in my ET correct?? What kind of decrease in ET's will I see with tubular LCA's?
Thanks!
Thanks!
LCA's would help out greatly with traction, but if you are going to get them then I would suggest getting some SFC's and relocation brackets. Getting all those traction parts will help you out greatly with launching.
realize that lca's are not neccessarily going to drop your ET's...they will help eliminate wheel hop which will help your launch and should drop your 60' times...but if all you are doing is spinning anyway, granted it may be spinning without wheel hop...you are still gonna have bad traction...
i noticed significantly smoother wheel spin...considering i had crappy old tires...but once i got decent tires..the grip was greatly increased..
carguyshu
Jan 22, 2017 11:19 AM
96SilverRam
Nov 20, 2016 11:19 AM
Henson071
Dec 30, 2015 09:55 PM
