Larger Injectors vs. Fatter Fuel pump
Old Mar 1, 2005 | 03:06 PM
Evil Eric's Avatar
which should come first in the fuel system build up? i already have a mid-size cam and im going to run a wee shot of nitro on top of that, would i be alright with a pressure regulator and injectors, or bump up the stocker duty cycle and throw a walbro 255 at it?
Old Mar 1, 2005 | 03:27 PM
BRENTT94Z's Avatar
Re: Larger Injectors vs. Fatter Fuel pump
1st comes pump, then comes injectors. You gotta supply the injectors w/ fuel 1st to run bigger injectors.
Especially if you run a wet kit. Your stock pump wont keep up.
If you run a dry, I would look into some bigger injectors in the near future, but why go dry.
The wetter the better
Old Mar 2, 2005 | 09:25 AM
Evil Eric's Avatar
so a bigger pump on stock injectors would yield results on a dyno?
Old Mar 2, 2005 | 09:31 AM
1-bad-z28's Avatar
It shouldn't because you are still supplying the same pressure from the regulator to the injectors and the injectors can only supply what they are rated at.
kaoticcamaross
Feb 17, 2015 03:13 PM
birdblack
Dec 30, 2014 06:59 PM
ANDYZ28
Dec 29, 2014 09:13 PM
Perry93TransAm
Aug 20, 2002 11:23 PM
