lack of oil pressure
Old Jul 14, 2004 | 03:12 PM
TigerWoodsJr's Avatar
I have searched and read through many oil pressure threads but can't really find what I want. I have an engine with 140k miles on the bottom end, then like 2k on the new heads and cam install. I can't seem to get more than 40psi of oil pressure when the car is warm, I only have like 43ish when it starts up cold. At idle I have like 18ish...I tried swapping to 20w-50 just to see if it made a difference and it didn't. Im pretty concerned about spinning a bearing or something since even up at 6k i don't get more than 40psi of oil pressure. Any ideas?
Old Jul 14, 2004 | 03:21 PM
grygst76's Avatar
Only one......new oil pump.
Old Jul 14, 2004 | 04:03 PM
Yeah...I dislike that idea...although I suppose it beats a new motor, right? In order to access the oil pump what do I need to do, drop the k-member, take out the oil pan and replace the oil pump? Would I have to take off the intake manifold to get to the oil pump drive thing in the back thing?
Stupid oil pumps.
Old Jul 14, 2004 | 04:25 PM
grygst76's Avatar
It's not really required...just make sure you keep everything clean. You could get away with lifting the motor up a little by removing the engine mount bolts and then getting someone to help, then dropping the pan makes life a lot easier. You only need to lift the motor up 4-6 inches for perfect clearance.
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
