catalytic converter is blocked?...
Old Jul 13, 2004 | 07:23 PM
Kurt Crosbie's Avatar
What is a catalytic converter supposed to look like?
What is the inside of the converter supposed to look like? I took the pipe after the converter down and looked inside expecting to see a bunch of messed up garbage, but it was just a white wall with horizontal and vertical lines on it. Is this normal? I don't understand hjow exhuast is supposed to get through with a freaking wall there.
Old Jul 13, 2004 | 07:31 PM
someone please help me. I've got the exhuast taken down. I was told to jam something into the converter to get the stuff out, but that thing in there is way too stiff
Old Jul 13, 2004 | 07:35 PM
kevinCHOPTICON's Avatar
big drill bit, a chizzle and a hammer. have fun gutting ur cat
Old Jul 13, 2004 | 07:36 PM
Cmr0z28's Avatar
It should look like a honeycomb inside. If it's clogged, don't bother scraping stuff out to save it. You'll damage it and ruin it. So, either gut it, or replace it with a high-flow.
Old Jul 13, 2004 | 07:53 PM
med_reject's Avatar
you have to bang that stuff hard. At first, it'll feel like you're trying to break through steel. I used a hammer and pipe and wacked at it for a loong time. The more you break through, the easier it gets.
Old Jul 13, 2004 | 08:00 PM
How can I tell by looking if that cat is my problem. When I looked in from the *** end, it looked like nothing was wrong with it. What does it look like when its good? What about when its bad?
I'm not getting any SES light, so I don't know what the problem (bogging) could be, besides the cat.
Old Jul 13, 2004 | 08:21 PM
bdc95ta's Avatar
run the car without it and see if your bogging is still there if it is it's probably not your cat or cats.
-b
!caution your car will **** off your neighbors, drive accordingly!
Old Jul 13, 2004 | 08:22 PM
Black6SpdTA's Avatar
My little brother's Firebird just had it's cat replaced. Totally clogged. The car wouldn't rev past 4k because of it. Now it's a 5500+ RPM 3.8
Do you have a high RPM problem? If not, I doubt it's your cat.
Old Jul 13, 2004 | 09:07 PM
med_reject's Avatar
I dont know how easy it is to take a cat off on a stock exhaust system. My stock cat bolts on and off the hooker catback. If you take it off and shine a light through it, u should see right through it, a very fine mesh. I would guess that a clogged cat would not look like that.
As for bogging, a lot of things can cause that. Plugs (take a few off and look at them), wires, opti, fuel pressure, the list is a lot bigger than that but these are the most common
Old Jul 14, 2004 | 02:44 AM
Lower's Avatar
This is what my good cat looked like from the back end.
Old Jul 14, 2004 | 04:11 PM
That picture is pretty much what mine looks like. Would looking at the back of it not tell the story? Does a bad cat and good cat look the same from the back?
Old Jul 14, 2004 | 05:36 PM
Larry95Z28's Avatar
The only way I could tell mine was bad was the car was bogging really badly one night. I lifted the hood and my exhaust manifolds were starting to glow red. So I took the handle from my 2 1/2 ton floor jack and stuck it in the back of the cat(it was still on the car) and beat the s*it out of it. Then started the car and blew all the stuff out of it. If you don't need one for emissions I would just gut it, it's not that hard and doesn't take too much time.
Sergio
Jan 27, 2016 04:27 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
Redbird
Sep 14, 2002 09:18 AM
Redbird
Jul 20, 2002 06:08 AM
