Kooks new LT1 Headers!!
Old Sep 16, 2004 | 06:25 PM
  #16
chucks97ss's Avatar
Re: Kooks new LT1 Headers!!
Originally Posted by Kreinmc
What is the advantage to going with stepped headers? Plan on going all out with a bolton application and need the most power I can get. Will these make more power than a hooker LT on a bolt on car? Would a 3.5" collector be too much or will it gain me a lot of power up top? How will ground clearance be with the 3.5" collectors? Let me know. I am interested in these.
With a stepped header like this, you have the velocity of a 1 3/4 header right out the valve, and the flow of a 1 7/8. I would only use a 3 1/2 collector if you are using a big shot of spray... Not sure about ground clearance...
Chuck
Old Sep 16, 2004 | 06:28 PM
  #17
Houdini's Avatar
Are any of the primary's a slip fit design?
Is the collector a slip fit design?
Old Sep 16, 2004 | 06:31 PM
  #18
chucks97ss's Avatar
No, as far as I know these are fully welded.
Chuck
Old Sep 16, 2004 | 06:37 PM
  #19
Z-RATED94's Avatar
Chuck, These headers will fit without hacking up my car? I really could use a set of long tubes now that the heads and cam are done. Would the stepped headers be to much for a small cam and set of LE heads. Also, what makes these headers better than a set of Hookers or Dynatechs? Do they come with a merge collector? Iv'e heard good things about Kooks headers, but I'd like to know why I should buy these instead of the other brands.
Thanks, Rick
Old Sep 16, 2004 | 06:38 PM
  #20
Houdini's Avatar
Thankyou very much Chuck, that was the answer I was hoping for. My day just got a little better.
Old Sep 16, 2004 | 09:27 PM
  #21
Highlander's Avatar
what kind of coating?? i ahve black coating on my headers and i like them...
Any idea of similar coatings?? better coating than the polished silver? i don't care if they are white, i care that they are the better or best coating around for heat.
I'm still debating on a few things though.. $900 for a set of headers when i have a set is to be considered...
Headers and exhaust give very good gains when supercharged/nitrous.. but i'm debating if its really a difference as i have not seen much when playing with eapro.
Old Sep 16, 2004 | 09:38 PM
  #22
stik6shift93's Avatar
The stainless versions come in straight stainless i believe so there's no coating which is a good thing. On my flps the coating has completely come off of the collectors and y-pipe. If i could have gone back i would have just bought a stainless header since they're not anymore expensive. Unfortunatly they didn't have any available back then .
Old Sep 16, 2004 | 09:51 PM
  #23
Z-RATED94's Avatar
stik6shift93,
Wouldn't the coated ones do a better job of keeping the under hood temps down a little? Don't get me wrong, I like the way the stainless ones look.
Old Sep 16, 2004 | 09:59 PM
  #24
Good point! I'd still rather have the stainless headers though, i talked to loko performance who coats the flp headers and they told me it'd be about 3-4 weeks for my headers to get recoated plus the time it takes to ship. Kind of a pita but i'll just wait until winter comes and then send them out.
Does anybody know how well the stainless steel does compared to a coated header in retaining the heat?
Old Sep 16, 2004 | 10:03 PM
  #25
Highlander's Avatar
coating is a HUGE advantage in retaining heat.
Old Sep 16, 2004 | 10:41 PM
  #26
bad95formula's Avatar
Hmmm.....im trying to decide if it would be worth it to switch from my ported AS&M's or stay. ill be running a blown 355. hmmmm....i gotta wonder how this would flow with say a mufflex. what other "quality" catbacks would fit with the 3 1/2 inch collector? Maybe i'll fab up a true dual system!!! Now i'm gettin ideas!!!
Old Sep 16, 2004 | 11:14 PM
  #27
Spinner's Avatar
Or you can get the stainless coated and have the best of both worlds.
Old Sep 17, 2004 | 11:50 AM
  #28
Z28SORR's Avatar
Exactly what I was thinking.
Old Sep 17, 2004 | 12:03 PM
  #29
RealQuick's Avatar
Food for thought...I dont know what SS grade the kooks are made of, but the SLP shorties are stainless as well and I has a set that wasnt coated and they browned out.
Old Sep 17, 2004 | 12:16 PM
  #30
Mindgame's Avatar
Yep, some of the cheaper grades of stainless steel (like 409) will rust given enough heat and time.
Most guys like Kooks don't use 409 though... usually 304 SS.
-Mindgame
