knowledge request
Old Sep 22, 2003 | 05:58 PM
lt1hatesme's Avatar
knowledge request
somebody please let me in on some hints dealing with plug wires. i have ruined two wires on the passenger side already (1 week) the MSD wires are dangerously bigger than the stockers and im having trouble finding a place to rout them without putting them in harms way. any help would be MUCH appreciated.
Old Sep 22, 2003 | 06:25 PM
lt1hatesme's Avatar
am i going to have to remove the bracket right there just to get the wires in there?? im talking about the passenger side by the way.
Old Sep 22, 2003 | 06:37 PM
RamAir95TA's Avatar
With stock manifolds, you don't have many choices with routing locations. Maybe you should invest in a set of headers, and kiss your plug wire issues goodbye with an over-the-valve-cover kit?
If not, all I can suggest is that you go ape with zip-ties and fire-sleeves.
revtime's Avatar
Do you have headers or manifolds?
I have MSD wires and LT headers. I run the passenger side wires through the bracket except for #2 which I run in the stock location behind the PS pump.
I put convoluted tubing over the wires so they would not get damaged from rubbing on the bracket.
I have almost 3k miles on my setup so far and not one burnt wire.
Run them away from header or manifold heat and use Zip ties to keep them in place.
Its not hard to keep wires from burning you just need to pay close attention to routing.
Old Sep 22, 2003 | 07:34 PM
lt1hatesme's Avatar
its just really hard because i cant see or reach the stock routing path, behind the steering pump. even with the car on a lift and one of the fans removed, i have a hard time getting in there.
Old Sep 23, 2003 | 05:30 AM
revtime's Avatar
Yes it can be a real pain trying to get your hands in there, the very first time I changed plugs and wires it took me 2 days.
Just be patient and maybe remove the alternator to give you some more room.
Old Sep 23, 2003 | 08:39 PM
BigRich's Avatar
definitely remove the alternator
definitely buy 1200 F heat sleeves
i swear to GOD the next time i do wires i'm going OVC!!!!!!!!!!
Old Sep 23, 2003 | 08:52 PM
lt1hatesme's Avatar
will over the valve cover wires work fine with stock exhaust manifolds?? or should i just let the car sit til i get some headers??
because im not driving it right now, nor wil i until i get this plug wire thingy situated
Old Sep 24, 2003 | 01:03 AM
revtime's Avatar
OVC will not work with manifolds.
Its not that difficult to get the wires routed just get in there and get r done.
Old Sep 24, 2003 | 07:28 AM
lt1hatesme's Avatar
how will it work with shorty headers?
Old Sep 24, 2003 | 10:48 AM
revtime's Avatar
I am not familiar with shortys, I have LTs, but I would think the OVC would work fine with shorty headers.
Old Sep 24, 2003 | 07:14 PM
lt1hatesme's Avatar
i sure hope so, i guess i will have to wait til next month to find out.
GREEN3112
Feb 10, 2019 09:19 PM
4586
Parts Wanted
May 1, 2016 10:25 AM
Quickss96
Jan 29, 2016 05:56 PM
93 RedBird
Nov 15, 2015 08:24 AM
surreybrad
Sep 29, 2015 09:00 PM
