knocking noise coming from bottom end of my new stroker
So I finally got everything finished and did the first start up and heard a knocking/banging noise coming.from the bottom end.. everything is new and I think I may now.what the problem is.but not sure.. I have a stroker crank and used my stock pan without modding it.. has anyone else had problems like this with that sound? Prolly can't get to it.today but gonna drop the.pan tomarrow..I'm hopeing that's what it is....
I had to clearance my block, with my set up. I rotated the engine over by hand and checked one piston at a time. I also have stroker oil pan for extra clearance. Did you anything during the build? ray
Re: knocking noise coming from bottom end of my new stroker
With my Callies 3.75" crank, it took no more than a couple gentle taps on the stock pan. What stroke are you running?
Although the block was clearanced the pan probly wasn't. On mine I had to drop the windage tray about 1/4", clearance the pan for number 6 rod at the pan rail and the front bottom of the pan for #2 rod. All pan clearancing was done with a brass rod and a dead blow.
Took it off this morning and the number 2 was rubbing, took a ball pein to it to make a little bulge, cleaned everything up and put 8 bolts in the pan, had to go buy some new oil because there was tons of shavings in the oil... fired it up and no more sound!! Made me pretty Happy! I had to take the bolts out of the pan 1 side at a time because i forgot the dumb reinforcement rails lol.. So I have 1 side all in and need to put 3 more in the other side(took a break to come eat and fill you guys in) already ate so now im going to go at it again!! hopefully that is the only problem.. might hook my exhaust up tonight to if I have enough time.. Thanks for the help and by the way it is a 3.75 crank.. hopefully if I can get it to idle tonight ill shoot a video or 2 so you guys and hear my cc xfi292 thumping ;-)
