knock sensor removal ?
Old Nov 11, 2007 | 04:38 PM
caminiti45's Avatar
I flushed the radiator today and went by the instructions on shbox's site and they recommend removing the knock sensor and block plug as well. I removed the knock sensor, but no water/antifreeze came out. I couldn't get to the block plug. anyways even with the system refilled I get no water comming out of the hole. Whats the deal?
-Rob
Old Nov 11, 2007 | 05:15 PM
Stl94LT1's Avatar
It must be block with gunk. Push something in the hole and clear it out.
Oh, and get ready for a coolant bath.
Old Nov 11, 2007 | 05:31 PM
caminiti45's Avatar
I'm also noticing up to 10deg knock retard just reving the engine in park. does the same in drive when taking off from a stop. wonder if not having the sensor in water is messing with the sensor?
Old Nov 11, 2007 | 05:35 PM
Stl94LT1's Avatar
Probably not, I'm pretty sure the knock sensor picks up vibrations from the block.
FYI: It is important to not tighten the KS too tight, or it can retard the timing.
Old Nov 11, 2007 | 09:33 PM
Definitely a problem, and probably the cause of the knock retard. If you have solid sludge packed into the space between the cylinder walls and the sensor, you are transmitting every vibration in the engine directly to the sensor, which is nothing more than a tiny piezo microphone. I saw a tiny piece of silicon seal get lodged in the end of a knock sensor, and cause a large amount of knock retard.
HectorM52
Jul 30, 2017 11:46 AM
BigWil
Mar 29, 2015 12:24 PM
4586
Mar 18, 2015 06:31 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
