Knock sensor question
Old Oct 18, 2003 | 11:13 AM
ead94z28's Avatar
Question Knock sensor question
Other than just putting a socket on the knock sensor and removing it, are there any other things I need to do prior to taking it off?
Old Oct 19, 2003 | 10:38 PM
Be prepared for coolant to pour out the hole.... the KS is screwed into the block drain hole.
Old Oct 19, 2003 | 10:46 PM
ead94z28's Avatar
So it can be done without draining the coolant by quickly putting my thumb over the hole?
Old Oct 20, 2003 | 01:51 AM
QCKZ28's Avatar
ead94z28 So it can be done without draining the coolant by quickly putting my thumb over the hole?
i suppose so, but it will be messy. taking the knock sensor out is the only way to drain the coolant from the pass side block. just put a pan under it and drain it, then replace KS and coolant.
jesse
HectorM52
Jul 30, 2017 11:46 AM
IgorT.455/406
Feb 1, 2005 06:18 AM
Nostang 96z
Sep 10, 2002 08:54 PM
96z
Sep 5, 2002 07:53 PM
NJ SPEEDER
Jul 19, 2002 10:22 PM
