Knock Sensor Problem Please help fast
Old Jan 18, 2007 | 06:21 PM
blaze309's Avatar
Ok a while back a bunch of the wires under my car caught on fire. Well my knock sensor wire got burned and now im not sure where the other end is. Is it a blue wire? Also is there anyway i can put a resistor on the wire if i can find out? I'm thinking this is why my car hasent been running as good.
Old Jan 18, 2007 | 07:02 PM
Blue wire. Click item #1. You are correct that your car will not run as well with the sensor disconnected. The computer will hold back timing to protect the engine while the sensor is out of commisison.
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Feb 5, 2015 05:14 AM
IgorT.455/406
Feb 1, 2005 06:18 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
