Knock Sensor Problem, Need Help
Old Sep 3, 2004 | 08:12 PM
JDBlaze85's Avatar
Ok my friend just bought a 97 Z28 and this is what we do know. It has a cam, some headwork, headers, exhaust, and the PCM has been sent off to be tuned. Now the problem.........It is pinging at part acceleration and some at WOT. The knock sensor is stock and is showing retard of up to 10-14 degrees at part throttle(mostly at first gear hard launch). After 2nd gear comes in, the KR goes back to 0, power is restored and the car flies the rest of the way. The KR is showing 3-5 degrees at normal idle and 6-10 degrees at part throttle(minor part throttle). If you slam the throttle, it will ping noticebly. We then tried a LT4 knock module and it still pings. No scan passes on the LT4 module. So I'm thinking of desesitizing the knock sensor with a resistor to keep the KR at 0. My question is: would the engine ping with retarded timing? I thought it only pings with too advanced timing? When the KS is pulling, the car runs like crap and when it goes to 0, you can really feel it back to normal. Could the PCM be tuned to advanced? Or is the pinging from the KS? Any input would be appreciated.
Old Sep 3, 2004 | 08:20 PM
S8ER95Z's Avatar
Re: Knock Sensor Problem, Need Help
Have you tried 100+ octane to see if its false knock?
Old Sep 3, 2004 | 08:24 PM
JDBlaze85's Avatar
nope.......Im figuring its false because it has knock retard at idle and it worsens at the slightest throttle. the knock retard goes away after the car gets going (2nd gear and up). I was thinking maybe the engine was runnin too lean, but the car pulls faster the longer you hold the throttle???
Old Sep 3, 2004 | 08:50 PM
zx1216's Avatar
Ahhh, if it is pinging it isn't false knock buddy, you should pull some timing out because it is probably too much for that set up, try runing some race gas through it and see if it goes away. if it does pull the timing out some. You best bet is to have it dyno tuned.
Old Sep 3, 2004 | 09:56 PM
JDBlaze85's Avatar
why would a tuner advance timing that bad in the first place? and what octane is best to try? I can get a hold of some leaded 106, 110, 112, and or 116?
Old Sep 3, 2004 | 11:13 PM
Don't put leaded in there...
Old Sep 3, 2004 | 11:14 PM
JDBlaze85's Avatar
will that kill the 02s?
Old Sep 3, 2004 | 11:20 PM
JDBlaze85's Avatar
Lightbulb Re: Knock Sensor Problem, Need Help
is there anyway I can pull timing without having to send the pcm in the mail or dyno tuned? any simple tricks or is there any tuning program I can buy so I can do it myself? links would be useful.
Old Sep 4, 2004 | 03:48 AM
S8ER95Z's Avatar
Get a cable from www.AKMCables.com and there is LT1edit, tunercat, etc.. plenty of software available.
Old Sep 4, 2004 | 08:40 AM
JDBlaze85's Avatar
thanx bro
HectorM52
Jul 30, 2017 11:46 AM
4586
Mar 18, 2015 06:31 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
Nostang 96z
Sep 10, 2002 08:54 PM
NJ SPEEDER
Jul 19, 2002 10:22 PM
