knock sensor in 93 camaro vs. 94
Old Sep 16, 2010 | 12:27 PM
tylerwerrin's Avatar
Hi guys,
I'm doing a swap from 93 to 94 PCM/wiring on my 93 camaro. I was wondering if the knock sensor in my 93 block is the same used in a 94/95. Or will I have to swap it?
Conversely, if i were to swap my 93 to a 96 wiring harness, could I use one of my B-body knock sensors (i had 2 of them off an engine that cracked its block), on my Fbody?
Also as for the knock module -- i've read differing things on using a stock F-body module vs. an LT4.... should I keep hunting for a reasonably priced LT4 module, or just go with the Fbody one?
thanks!
Tyler
Old Sep 16, 2010 | 12:53 PM
Mr_Bond's Avatar
The knock sensor are the same from 93-95. 96-97 have a different knock sensor.
Old Sep 16, 2010 | 01:02 PM
Do you know why the Fbody used 1 knock sensor, and the B body used 2?
NewsBot
Dec 28, 2014 06:20 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Jul 4, 2005 05:00 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
