Carbon Pellets in EVAP Line
Old Sep 12, 2010 | 09:09 PM
1quickTA's Avatar
I was pulling things off my intake manifold (working on fixing the intake leak) and found that the curved rubber line between the EVAP vacuum switch and the EVAP canister solenoid valve (in image below) was FULL of carbon pellets.
What does this mean exactly, and what do I need to replace/repair it? I have never thrown any codes for this and didn't notice any issues prior to seeing the carbon pellets.
I read that it means the EVAP canister is clogged.
Old Sep 12, 2010 | 09:16 PM
95TA04GOAT's Avatar
It means the charcoal in the evap canister is breaking up. The broken pieces can get into evap solenoids or valves causing them to stick open or closed, which will set a code on obdII cars (96+). The canister has to be replaced and lines cleaned out.
Old Sep 13, 2010 | 09:05 AM
wrd1972's Avatar
Like already mentioned. The filter in the top of the cannister is ripped and the engine is sucking in the pellets. Chances are the plastic tube on the front and the solenoid are clogged up.
I have managed to clean the tube and the solenoid in the past. Clean the tube by using degreaser and something you can shove in it to break up the clog. The solenoid you have to carefully cut open and disasseble to remove the pellets.
If you decide to repair the EVAP, put a filter on the line exiting the cannister that runs to the motor to prevent it from happening again.
Old Sep 13, 2010 | 09:15 AM
1quickTA's Avatar
Wow those EVAP canisters are more expensive than I would have thought
This is a crappy year for my car! Trans dies, windshield cracks, various oil leaks, a few nails in tires, dead window motor...
Old Sep 13, 2010 | 09:19 AM
wrd1972's Avatar
Yeah they are terribly overpriced. I bought a used one for $20 off the board and put it on the shelf. It seems to be good but its a roll of the dice.
You could just delete the EVAP and vent the tank to atmosphere. You will smell gas fumes more kind of like the cars of the 60's.
Old Sep 13, 2010 | 12:17 PM
1quickTA's Avatar
What would the issue be if I kept the canister as is (less carbon pellets I guess), put an inline filter to stop more from migrating down the line, and just ran it like that? The system would still be closed so I shouldn't small fuel, right?
Also, with the canister being in the rear driver-side wheel well (according to my manual), the carbon pellets could be from there in the line all the way up to the intake. Any tips on how to clean it out? Compressed air maybe? Also, any tips on how to clean out the switch/solenoid?
Old Sep 13, 2010 | 01:15 PM
Wild Willy's Avatar
Your computer probably monitors being able to pull and hold a vacuum on the fuel tank- the purge solenoid and the evap solenoid cycle at different times, to burn off the accumulated vapors from the canister. I had an evap solenoid fail on my S10 truck, and it was intermittent. Would set a light, code 301 IIRC, and would stay on for while, then go out- took me almost 2 years to chase it down and replace the correct solenoid, which only cost about 15 bucks. I would try to find a good canister at a recycling yard, for cheap- if that didn't work out, I suppose you could try an in-line filter, like a fuel filter, to stop the carbon from migrating- but that line needs to be able to pull the vapors enough to place a vacuum on the fuel tank- or the OBD II will be unhappy.
Old Sep 13, 2010 | 02:50 PM
1quickTA's Avatar
I guess I'll try to get a new canister from a junk hard. I'm surprised that I didn't throw any codes with it as it was.
Old Sep 13, 2010 | 03:06 PM
NJ-LE's Avatar
I've never had the charcoal canister problem but if the cost is so high I'd check the phone listings for a laboratory supply house and price a jug of activated charcoal granules. They're probably available in the same size granule as needed to refill the canister. I think some pet supply houses also sell granules for refilling air purifying canisters for fish tank air pumps.
Old Sep 13, 2010 | 06:32 PM
wrd1972's Avatar
Only get a code if the solenoid is disconnected.
Old Sep 14, 2010 | 07:12 AM
1quickTA's Avatar
If I just disconnect the hose to let it vent to the atmosphere and plug the hole in the intake just so that I can drive around until I get it all fixed, might that be an issue or no?
Old Sep 14, 2010 | 04:46 PM
Originally Posted by Wild *****
Your computer probably monitors being able to pull and hold a vacuum on the fuel tank- the purge solenoid and the evap solenoid cycle at different times, to burn off the accumulated vapors from the canister. .....
What is the difference between the "purge" solenoid" and the "evap" solenoid? Per the emissions diagrams, there is only a single solenoid - the "evap purge" solenoid mounted on the bracket on the passenger side of the intake manifold.
Old Sep 16, 2010 | 04:51 PM
1quickTA's Avatar
Thoughts about temporarily plugging the intake (to prevent vacuum leak) and just leaving the end of the EVAP line open to vent to atmosphere until I get around to fixing it?
HectorM52
Jul 30, 2017 11:46 AM
carguy0119
Apr 11, 2016 11:11 PM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
Jazsun
Dec 29, 2014 12:14 PM
