Knock Retard!!! I just found out!
Old Aug 30, 2004 | 12:58 AM
CColtManM's Avatar
I just plugged in a laptop and went on the street. I found i have upwards of around 6.5 degrees of knock retart. Now, my traction control was on, which increases it a few degrees i hear, but still, thats a hell of a lot. What can i do to lower this?
Old Aug 30, 2004 | 01:13 AM
Dave19yz28's Avatar
Re: Knock Retard!!! I just found out!
LT4 knock module will help out...you can also get your computer reprogrammed....check out Madz28.com and shoot Ion an email if you are going with the computer reprogram...but definately get the LT4 KM...
http://samtaylor.com/html/parts.html
give Jason Cromer a call at Sam taylor Caddy...p/n 16214681
Old Aug 30, 2004 | 03:30 AM
1racerdude's Avatar
If it's FALSE knock from header's or valve train or exhaust leak you can do a search on the board and get the resistor number and go to Radio Shack,get one for a few bucks and wire it in line with the KR sending unit and do away with the retard the computer is doing.That will save you the money for a LT-4 module which doesn't work all the time and you still have to do the resistor.
cmsmith
Apr 11, 2015 09:37 PM
maybe2fast
Mar 16, 2015 11:59 AM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
BLU98Z28
Sep 11, 2002 07:37 PM
Firehawk#69
Sep 8, 2002 09:23 PM
