knock retard
Old Oct 5, 2006 | 08:11 PM
kline454's Avatar
knock retard
My camaro is pulling 1degree of time at idle and 2 degrees at wot, I replaced my knock sensor same thing and my knock module with no diff made, i also checked my wire to my knock sensor it has the 5v with wire off like it should and the sensor has 3800ohms of resistance and spec is 3500 to 4500 so thats good. so i put a resistor 3800ohm from the wire to ground. and the car still pulls 1 degree at idle and 2 degrees at wot, any know why this is?
Old Oct 5, 2006 | 08:16 PM
wrd1972's Avatar
Re: knock retard
I am pretty sure tha 1-2 degrees will not hurt performance.
Do you have the LT4 knock module?
Old Oct 5, 2006 | 08:21 PM
kline454's Avatar
Re: knock retard
yes its a lt4 module and i dont think its hurting me to much just driving me crazy.
Old Oct 5, 2006 | 08:25 PM
kline454's Avatar
Re: knock retard
i didnt know if anyone elses car does this? im about ready to replace the pcm.
Old Oct 5, 2006 | 08:33 PM
kline454's Avatar
Re: knock retard
Help!!!!!!!!!!!!
Old Oct 6, 2006 | 08:49 AM
quicksilver97ta's Avatar
Re: knock retard
Thats a good one, I would suspect the pcm also. Did you try just leaving the wire unpluged? You might try the computer diag forum if you dont get answer here.
Old Oct 6, 2006 | 09:14 AM
Re: knock retard
Any possibility you have a high voltage (plug) wire running right next to the knock sensor harness?
Old Oct 6, 2006 | 11:39 AM
kline454's Avatar
Re: knock retard
There are no plug wires around the knock sensor wire i moved them all. and if i unplug the wire it pulls 12 degrees at idle then from 1500 up it doesnt pull any timing.
Old Oct 6, 2006 | 11:42 AM
kline454's Avatar
Re: knock retard
I would like to see some data logs of other cars, to compare to mine.
Old Oct 6, 2006 | 03:55 PM
Re: knock retard
With the 3800 ohm resistor in the circuit, what is the voltage measured across the resistor?
Old Oct 6, 2006 | 06:13 PM
94CamaroZ28's Avatar
Re: knock retard
Try some race gas, see if it goes away. If it's real spark knock, it should disappear with race gas. If it does, tune might need a little less timing.
Old Oct 6, 2006 | 07:45 PM
kline454's Avatar
Re: knock retard
110 no diff samething
94Maroz28
Oct 27, 2015 04:38 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
asilomar244
Jul 12, 2015 05:53 AM
