Optispark Waterproofing????
Old Oct 5, 2006 | 06:28 PM
LT1Jeepin's Avatar
I run a 95 LT1 in my Jeep and I don't play in anykind of really deep water because of the Optispark. However some trails that me and my club go to require the fording of a stream of some kind sometimes. My question is, Is there anyway to make the opti as water proof as I can. I hope it never gets completely submerged and I always check the depth of the water first but I still worry about it. Any help would be appreciated. I looked at delteq's system but I think it still uses the optical triggering. Is this correct? Also that wouldn't really help my case would it?
Old Oct 5, 2006 | 06:49 PM
wrd1972's Avatar
Re: Optispark Waterproofing????
The Delteq still uses the optical sensor in the opti.
You can try running beads of RTV or urathane aorund the seam joints of the casing.
Old Oct 5, 2006 | 07:12 PM
Dave89IROC's Avatar
that is what I am going to do with the opti in my K5
Old Oct 6, 2006 | 07:48 PM
cat back 21's Avatar
I know Corvette Clinic retrofits opti spark dist, for 100 bucks they will turn it into a vented opti. But you are going thru rivers and streams, that might be to much even for a vented opti. You can email them at info@corvetteclinicinc.com . I am planning on buying a new npn vented opti from summit and sending it to them for a retrofit.
Old Oct 6, 2006 | 08:05 PM
Mtrhds94Z's Avatar
cat back 21 a 95 already is vented..
And you can do the venting yourself, if your handy..
See:
http://www.corvettefever.com/howto/16758/
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
colts0455
Sep 27, 2015 01:07 PM
Z Power
Sep 19, 2015 11:19 PM
