killing fuel pumps
Old Sep 26, 2011 | 09:20 PM
r1scooter's Avatar
killing fuel pumps
I have a 97 lt1 camaro I am killing my fuel pumps. I have gone through 3 fuel pumps in 300 miles. The first 2 were walbro 255 the last one was a aeromotive. The last one I put in was put in also with hard wiring it to the ignition and installing aeromotive fuel pressure reg and new 44 lbs injectors. The car runs fantastic for about a tank of gas then takes a ****. Anyone have any ideas on what to look for or where to go from here im at a loss.
Old Sep 26, 2011 | 09:51 PM
JooneJune's Avatar
Re: killing fuel pumps
mines doing the same thing, blowing through 255lph walbro's. Setup is OEM reg on 36lb injectors.
I'm going to try and keep the unit cool by keeping a full tank of gas.
Old Sep 26, 2011 | 10:20 PM
Feenix's Avatar
are you running the tank below quarter tank? Most aftermarket pumps don't respond very well to it. You wanna at the least stay over a quarter tank. I try to stay over half. The fuel in the bucket keeps the pump cool.
Stock pumps handle running the tank dry better than aftermarket pumps. Though that does seem a bit excessive to burn em up that fast.
Old Sep 27, 2011 | 12:53 PM
RamAir95TA's Avatar
Might be a short or faulty wiring.
Old Sep 27, 2011 | 08:06 PM
punkslapper's Avatar
could be crimped , kinked or somehow resticted fuel line.
Old Sep 27, 2011 | 08:54 PM
JohnD's Avatar
I hate to even say this but when is the last time the fuel filter was changed?
Old Sep 28, 2011 | 06:02 PM
r1scooter's Avatar
The fuel filter is new flows great cant find any kinks in any lines and when each pump goes in they run great 42lbs of pressure at the rail constent until i go about a 100 miles then it has a very hard time cold starting a couple of times then it just dies completly.
Old Sep 28, 2011 | 06:12 PM
Have you checked the voltage at the fuel pump harness connector?
Old Sep 29, 2011 | 11:36 PM
97WS6SCharged's Avatar
Are the socks gummed up when you remove the busted pumps? What about the fuel filter?
Old Sep 30, 2011 | 05:19 PM
r1scooter's Avatar
harness is good the fuel pump is hard wired into the ignition with an inline fuse and relay and the fuel is spotless and the socks still look brand new
grabbem88
Apr 16, 2015 06:57 PM
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
