Just Removed Waterpump What Hoses Can I Bypass And Eliminate??
i currently have my water pump removed and was wondering when placingthe new gaskets on which exact sealant should i use to this damn thing wont leak again also what hose can i eliminate?? like throttle body and heater hose is there a diagram somewhere that shows which passages go to where?
Re: Just Removed Waterpump What Hoses Can I Bypass And Eliminate??
This stuff works great on the waterpump and is available at any autoparts store:
http://www.partsamerica.com/ProductD...rtnumber=22071
The only thing you can bypass is the throttle body. Do a search and you'll find more info than you could ever need.
Shoebox has the diagram:
http://shbox.com/1/93-94_hoses.jpg
You could eliminate the heater, but it might not be too good if you live in a cold climate.
so theres no way to eliminate the long hose running through the firewall to the water heater and back?
oh thats fine i live in fl and no matter what climate its always hot as hell thanks for the help again fred and idea what hoses to block off from there?
Victor Lamb
Aug 26, 2017 02:52 PM
SMO Q
Feb 11, 2015 07:13 AM
