just put my cai on
Old May 29, 2010 | 10:38 PM
northdakota93z28's Avatar
just put my cai on
just put a morso cai on and cant tell any diff.
my car pulls like crazy in first with my mt 410's and stall but as soon as i shift into second it is slow third is even worse it takes me a long time to get to the top of third 109mph
just wondering what other guys with my same mods think
feels super slow except first. then it is like a rocket.
Old May 29, 2010 | 11:23 PM
greenmachinedriver's Avatar
you really wont notice any set of the pants difference with just adding a cai. mabey 10 hp is not enough to tell a difference. if it dont feel fast enough you must need more mods!
Old May 29, 2010 | 11:45 PM
Fatdog2's Avatar
Did you remove the negative battery cable for a couple of hours so the computer can learn the new stuff?Just a thought.Hope this helps.Otherwise it may take a while for changes to be learned.My02.
Old May 30, 2010 | 08:21 AM
There is nothing for the PCM to "relearn" with a CAI. Any very minor changes in air flow are picked up by the speed-density calculation (93) or by the MAF (94-97). And you don't need to unhook the battery "for a couple of hours" to reset the very few pieces of data stored in the PCM's volatile memory. Pull the "PCM BAT" fuse for 30 seconds.
You aren't likely to feel the differnce in the 10HP or so provided by a CAI. As noted a few posts above, that's below the threshold of the SOTP dyno. And if your car is struggling in anything other than 1st gear, the CAI isn't the fix. Its a more serious problem that you have to track down.
Old May 30, 2010 | 10:38 AM
i dont think its a problem i just think it is slow.
Old May 30, 2010 | 12:08 PM
Might want to run the 1/4-mile and get a complete timeslip. That will give you the data to compare performance in 1st gear to performance in 2nd and 3rd, further down the track.
Obviously, 2nd gear isn't going to "pull" like 1st gear, because the gear ratio change has just dropped the torque at the rear wheels by almost 50% (4L60, 3.059 1st gear, 1.625 2nd gear).
Old May 30, 2010 | 10:35 PM
1/8 mile tracks is all i have
it is a heavy, light moded car. so it is expected not to be super fast.
i have not sprayed since my stall. i bet when i spay 2nd and 3rd my car will be quick
97ChameleonTA
Jun 4, 2015 08:19 AM
alex5366
Feb 17, 2015 09:07 AM
ModdedNerd
Feb 5, 2015 04:37 AM
Z28STYLE23
Aug 17, 2002 07:40 PM
Absolute Z28
Jul 19, 2002 02:21 PM
