Just had my first dyno run....NOT GOOD!
Old Jul 21, 2003 | 11:40 AM
  #16
Camaro_Maniac63's Avatar
If you want to correct the A/F ratio, you need to get your car tuned. When I say tuned, not Hypertech tuned, but real dyno-tuned. The mail-order guys on this board do a very good job at tuning also from what I have heard. But before getting a tune, I would get a Cold Air Intake and headers. Those should help your numbers.
Old Jul 21, 2003 | 12:02 PM
  #17
NeoSNK's Avatar
Yeah I would recommend the cold air intake and the tb bypass mod. Thats good for about 25hp.
Old Jul 21, 2003 | 12:32 PM
  #18
RTICWOLF's Avatar
I have already done the TB bypass, but it looks like a CAI is in my future.
However, would it not cause an increase in my car being lean since I am increasing the air flow?\
Old Jul 21, 2003 | 12:33 PM
  #19
SlowAssTA's Avatar
Originally posted by revtime
I would be leary of going to all the trouble of putting a cam in a 111k motor.
I have 135k on mine and am just gonna wait till I build my new engine.
Lots of people do it though, so go for it if you want.
my motor has 160000 miles and i just did heads and cam, i dont have any problems...
btw my car dyno'd 280rwhp and 314tq with shortie SLP headers cutout, cold air, airfoil, hpp3...
Old Jul 21, 2003 | 12:45 PM
  #20
There will be a small increase in airflow, due to reduced pressure losses and colder air. That increased air flow will be seen by your mass-air sensor, and reported to the PCM. The PCM will add the extra fuel to go with the extra air. If it miscalculates, the long term fuel corrections, based on feedback from the O2 sensors will make the correction. That's the beauty of mass-air EFI.
You adjust WOT A/F ratio with the power enrichment (PE) tables.
Old Jul 21, 2003 | 01:42 PM
  #21
sorryofficer's Avatar
if your fans are coming on at those temps, i hope you have a 160thermostat, otherwise, you'll burn em out. With the kind of miles that motor has on it, i'd be pretty happy with those numbers
Old Jul 21, 2003 | 02:00 PM
  #22
turbo_Z's Avatar
i also think those numbers support your mods.
there are really only a few bolt-ons that do anything for hp and the rest are scams IMO. so the 4 listed below will yield the best results. and of those you have 1.
1. headers
2. catback
3. CAI
4. cutout
Old Jul 21, 2003 | 03:51 PM
  #23
RTICWOLF's Avatar
Thanks again everyone!
I do have a 160 stat, btw.....
Well, I asked on the pullies on this board before I got them and the general concensous was they would help a little. One person even made the point that add all those "little" things up and you get something worth while (not bad advice).
Well, glad to hear my numbers were ok....I was just a little surprised.
So....Fred, on those PE tables, how to I adjust them (higher or lower)? What RPM's? I just do not want to mess anything up, so the more info the better.
Thanks!
Old Jul 21, 2003 | 04:09 PM
  #24
You need to go on the LT1_Edit board and do a search.... there is a formula that tells you how to alter the PE vs. RPM and PE vs. temp tables to get a specific amount of change in A/F ratio. I don't use the stock PCM, so I don't know the formulas.
Old Jul 21, 2003 | 08:52 PM
  #25
RED95LT1Z28's Avatar
I only have the mods listed below and i got 274 rwhp and 310rwtq. A CAI so far is the biggest difference i have noticed in doing the small mods to my car.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
