just got pcm flash
Old Feb 7, 2009 | 12:06 PM
quickchek321's Avatar
Angry just got pcm flash
the car still wont idle but when i took of my intake it idle for about 2 min then die. when i press on the gas rev it up it will stay on with no intake but when i put on the intake it choke it self, seem like it back fire
cc306 cam, rocker arm 1. 52, longtube header ,pcm flash, b&m 2400
Old Feb 7, 2009 | 02:22 PM
dubbsix's Avatar
Who did your tune?
Who did you PCM tune? Once i had a crap'tacular chip from some guy off ebay and my car ran like crap until i ponied up and got a PCM4LESS tune.
Old Feb 7, 2009 | 04:18 PM
pcmforless
Old Feb 7, 2009 | 09:50 PM
You need to provide some basic info about your car. Why not add a "signature" with year, model, engine, tranny and any major mods. That way it will be easier for people to respond to your questions.
Have you scanned it for codes? You indicate you "took of my intake".... do you mean you removed the ducting from the air filter to the MAF sensor? Or did you also unplug the MAF sensor?
Old Feb 7, 2009 | 10:00 PM
Do not start multiple threads on the same problem. Post it once, and wait for an answer. You can push the thread back to the top AFTER 24 hours.
https://www.camaroz28.com/forums/sho...d.php?t=666897
Old Feb 9, 2009 | 10:52 AM
sorry im new at this, for some reason my car can't idle with the intake on unless i keep rpm up to stay runing but still wont idle
1996 firebird formula lt1 cc306 cam, rocker arm 1. 52, longtube header ,pcm flash, b&m 2400
Old Feb 9, 2009 | 08:37 PM
userchemical's Avatar
vac leak
make sure you put your elbow on properly
did you do your own cam install?
Old Feb 9, 2009 | 09:06 PM
slomarao's Avatar
Well to start you have to give way more information to get good answers. What [EDIT] you have given so far has got you poor [EDIT]answers.
Tell everything start to finish and try to make it so people can figure out your issues. Then you will get some real help
Last edited by Injuneer; Feb 11, 2009 at 10:43 PM. Reason: No need to start insulting new members
Old Feb 11, 2009 | 10:41 PM
You need to answer the questions that people ask. What parts are you talking about when you say "the intake"? Does that include unplugging and removing the MAF sensor?
Helpful Hint: To add a signature, you don't just space a new sentence down 10 lines. You left click on "USER CP" on the red tool bar at the top of the page, and click on "Edit Signature" on the drop down. That way, you "signature" is always added at the bottom of your post, without having to type it in every new post.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
94Maroz28
Oct 27, 2015 04:38 PM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
