No spark to coil Help
Old Feb 10, 2009 | 06:40 PM
Drew24's Avatar
Just did the optispark put it back together i checked the plugs and wires and it would only start up when it was cold but now it wont at all cause i fixed a vaccum leak.
All it is doing is turning over but no crank. I replaced the coil and the wire and still no spark to the coil.
The car was running fine before i replaced the opti just did it cause i had to replace the water pump im stumped please someone give me some input on what it might be
Old Feb 11, 2009 | 10:08 AM
pcgamer4life's Avatar
If it's not getting spark to the coil, it's either the PCM, ICM, or in the wiring somewhere I'd imagine...
Old Feb 11, 2009 | 08:08 PM
Drew24's Avatar
Thanks guys for helping me out i got her purring again it turned out that the people i bought the opti from gave me a bad one. Never again will i buy one unless its from GM
Old Feb 11, 2009 | 10:59 PM
That is what most people on here will tell you.
markzzzz
Aug 17, 2015 11:08 AM
greenzee28
Mar 26, 2015 09:13 AM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
tbyrne
Aug 16, 2002 01:12 PM
