just got car problems...
Old Feb 16, 2010 | 10:06 AM
  #61
Diplomat's Avatar
Originally Posted by fastcam91
Oh its not misfiring anymore my TPS sensor is getting low voltage
Excellent so is it fixed or is it still running rough.
Old Feb 16, 2010 | 04:25 PM
  #62
fastcam91's Avatar
it runs good, idles at 1k and backfires a little bit from the low volts on the TPS and also the rear whine. other than that runs good
Old Feb 16, 2010 | 06:31 PM
  #63
Diplomat's Avatar
It has to be one of the wires, I've seen so many good looking wires be bad. Some even tested good but once the load is applied the wire has nothing to hold it.
Old Feb 16, 2010 | 07:19 PM
  #64
GhostZ28's Avatar
you seem like you are very young.
welcome to the world of the F-body..
Get used to weird no-start problems, idle troubles, and all sorts of 4+hr jobs that would otherwise be retarded easy on other cars.
if you are still having weird issues, I once had a lemon PCM on my old 3.4L. sometimes I would get a no start and I would have to beat it with a hammer. I finally got tired of no starts and random times it would die and replaced the PCM with one with a stock tune. it ran perfect after that. I have a spare 1994 a4 PCM if you want to do an obd1 conversion.
Old Feb 21, 2010 | 12:58 AM
  #65
fastcam91's Avatar
i already mentioned previously that I HAD already changed to new wires and plugs, I am just getting a low voltage on the TPS code 122. Im trying to find a bad connection or bad ground. Its backfiring cause of the tps not wires anymore.
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
