just dynoed car- questions
Old Apr 30, 2003 | 10:02 AM
  #16
MeanGreen97Z's Avatar
Originally posted by jeremy reppert
ok couldnt get off work.
rpm a/f
5000 13.1
5100 13.1
5200 13.0
5300 13.0
5400 13.1
5500 13.1
5600 13.2
5700 13.3
5800 13.4
5900 13.5
6000 13.6
6100 13.7
6200 13.6
6300 13.6
cnc heads,oversize valves,ported intake,58mm tb,230/236,r lifters,30lb injectors,elec water pump,double chain, hooker lts,3"x pipe, bullets, & edelbrock sticker
That looks good to me. Maybe a slight bump in fuel pressure or a slight change in the fuel map. Other than that its good.
Old May 1, 2003 | 12:51 PM
  #17
jeremy reppert's Avatar
huh i was told it was lean
Old May 1, 2003 | 12:54 PM
  #18
IrocManiac's Avatar
Seems like you're about .3 or .4 down from what I remember a couple cars pulling on the dyno here locally a couple years ago.
Old May 1, 2003 | 12:56 PM
  #19
IrocManiac's Avatar
I worded that bad, a couple years ago they were about 12.7 to 13.2 or so, sorry for not making that clear...
Old May 1, 2003 | 01:00 PM
  #20
13.6:1 is actually not lean. You just tend to make a little more power with an LT1 if you lean it out a bit. As long as you dont have detonation then its not lean. If I were you I wouldn't be so worried about peak horse power as much as having a nice steep drive to at least 350rwhp from 4500-5800. With the numbers above that I would be more than happy. ESPECIALLY with stock internals. Dont spin it too high. It would be a good idea to do a little upgrading in bearings, fasteners, and an overhaul if you plan on taking it above 6000.
Old May 1, 2003 | 01:04 PM
  #21
CANTONRACER's Avatar
I actually plan on having my AFR around 13.0 the whole time and when I spray, I will just use fatter fuel jets to make sure I am around 12.0...but I have unlimited access to a chassis dyno...so that makes it easy...
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
alex5366
Feb 17, 2015 09:07 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
YellowT/A
Aug 7, 2002 12:30 PM
