just dynoed 1356hp
Old Feb 23, 2005 | 12:55 PM
  #46
fastestzaround's Avatar
Re: just dynoed 1356hp
Originally Posted by Joes94TA
No disrespect but I know people with engineering degrees that are lost when it comes to automotive... but since you posted that I am kinda curious how you only figured you would need just 83# injectors ,,,did you underestimate the hp potential when purchasing them ??? seems to me with you book knowledge you would have the formula for figuring injector sizing..
I didn't even come close to expecting that much power. I built it actually for one turbo and thinking around 800hp. Then i got the bright idea to put the other turbo on it and just see what would happen. This is just the first of many dyno's i will see before it's all over with. Things need changing and things needs to be adjusted and after all is said and done it should be putting out more than that.
Old Feb 23, 2005 | 01:02 PM
  #47
1racerdude's Avatar
With 83lb'rs@78psi you can make the 1350 HP with a 89.8 duty cycle and thats not unheard of if you have a good pump.
  #48
Originally Posted by CreatiVe2
wow.... you design This
That goes in That
I actually work more with the t701c which goes in the apache's. That is a Cobra with a t700.....i can't go into detail about them but they are basicly the same thing
Old Feb 23, 2005 | 01:03 PM
  #49
BADNEWZBEARER's Avatar
I'M HERE TO DO WHAT I DO BEST, BRING BAD NEWZ. I'M GONNA LIFT THE SKIRT UP ON FASTESTAROUND. TO LET THE WHOLE WORLD KNOW HE IS FULL OF BS. EVERYTHING IS FAKE I KNOW THIS MAN PERSONALLY AND HE DOESN'T EVEN OWN A CAMARO HE DRIVES A KIA RIO. HE ALWAYS TALKS ABOUT GETTING A CAMARO BUT WORKING AT MCDONALDS HE CAN'T AFFORD GETTING ONE. SORRY BUDDY BUT YOU'VE BEEN BUSTED.
P.S. CHECK OUT THE DYNO GRAPH PIC REAL CLOSE.
HOLLA
Old Feb 23, 2005 | 01:07 PM
  #50
thats funny as hell
Old Feb 23, 2005 | 01:10 PM
  #51
CreatiVe2's Avatar
well one things for sure... you know your aircraft engines...
  #52
lt4 fd's Avatar
I thought the dyno looked like a stock ls1 or lt1 dyno with the numbers on the sides changed.... seems like a motor like that would be more peaky like the other guy who just topped 1000rwhp not smooth and flat and having 1300lb ft at 2500 rpm so the graph just doesnt look right to me but whatever..
Old Feb 23, 2005 | 01:12 PM
  #53
Go Ahead Fastestaround Tell Everyone About Your Rice Burner Kia And The Mods You Did To It. This Man Says He Has The Fastests Kia Around Town. He Is Real Embarising To Ride Around With Considering The Loud Weed Wacker Muffler He Got And All Those Ridiculous Stickers All Over The Car. Then He Will Try To Race Everything Possible And Lose Everytime. Come On Man Just Give It Up. :d
Old Feb 23, 2005 | 01:25 PM
  #54
Where Did Fastestzaround Go
Old Feb 23, 2005 | 01:26 PM
  #55
Hey there badnewzbear....aren't you on the wrong forum? I think you were looking for boybuttbangers.com
Old Feb 23, 2005 | 01:29 PM
  #56
Your Kia Is Faster Than The Time It Took You To Come Up With That Insult.
Muahahahahahaha
Old Feb 23, 2005 | 01:33 PM
  #57
CreatiVe2's Avatar
are you guys serious?
  #58
Joes94TA's Avatar
this is true but doubtful with a aeromotive,,,maybe hes running a 16volt battery system??? ... then again if its true thats viable info I know I would have included ecspecially when detail listing parts as he done... then on the other hand if its a con in progress..we are just feeding the next successive con to come with more information that we've graciously has given him to use...
Old Feb 23, 2005 | 01:34 PM
  #59
hotrod18_69's Avatar
Well if ture or not.. Let see some pics of the engine setup.......
Old Feb 23, 2005 | 01:36 PM
  #60
earnhardtJR's Avatar
Yea, something is NOT right.... Considering hp is calculated from torque and rpm, how can you have horsepower lines on that dyno pic when there are NO torque lines (eg. from ~1500 rpm to ~2500 rpm)??? And there is no turbo lag to be found in the horsepower curve? 1150 horsepower at 1500 rpm? Seems fishy...
But if it is true, that is one badass motor!
