just dynoed 1356hp
Re: just dynoed 1356hp
Originally Posted by Joes94TA
Lucas, 83 lb/hr injectors, Aeromotive fuel pump and pressure reg., ??????????
1356hp x .60 BSFC / 8 x .80 = 127# inj. @ 80% duty cycle, even 100% = 101.7 #
not trying to disprove anything here,but your injectors are to small and you better ditch that aeromotive for a weldon..
Originally Posted by 1-bad-z28
unfreakin believable.
ibanez6rg, what numbers seem low? Sounds like this guy has things just right considering over 1300 hp!
Originally Posted by fastestzaround
seems to work pretty good
with no load it might,,with a load however i forsee molten pistons...
with no load it might,,with a load however i forsee molten pistons...Hell I got 83#s in my N/A lil 388 ... i might actually think if you told me you had (16) 83# injectors it would live...since I'm assuming you only are 1 injector per cylinder I feel you are in for another rebuild very soon..
I will let you know....hopefully by sunday or monday. I don't see any problems....but then again i am only a GE T700 Series Aircraft Engine Systems Engineer
Originally Posted by 1racerdude
Maybe ya ain't figguring fuel pressure???????
wow.... you design This
That goes in That
hope the injectors don't cause the issue Joes94TA says they do... with all of the $ invested i'd double check
