Just CHanged plugs and wires now huge problem
Old Aug 9, 2003 | 02:35 PM
1994CamaroZ28's Avatar
Got the job done with acell 9000 wires, checked firing order and everything but when i try to start it, it goes up to 2k then rough idles for a sec or so and dies what the hell is going on?
Old Aug 9, 2003 | 02:56 PM
wiked95ta's Avatar
Double check that you didn't coss a wire or two...
Old Aug 9, 2003 | 03:35 PM
Rich_z28's Avatar
Sounds like you've got a couple of crossed wires. This is the way the cylinders are numbered.
REAR
8 7
6 5
4 3
2 1
FRONT
Here is how the optispark wires are numbered.
Top
4 5
6 3
8 7
2 1
Bottom
Also the very top plug goes to the Coil.
Hope this helps good luck.
Old Aug 9, 2003 | 03:49 PM
Thanks for the replys i just found out that i was a dumbass and forgot to connect the vacumn line back to the brake booster that i tooked off to check my rockers, thanks for the replys guys.
PCLZ28
Dec 24, 2015 05:19 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Jazsun
Dec 29, 2014 12:14 PM
IRABuss
Sep 7, 2011 09:08 PM
