Just bought an B&M shiftplus electronic shift kit, doesnt work?
Old Oct 6, 2003 | 07:11 PM
94FBODY's Avatar
I just bought a B&M Shift Plus Electronic shift kit, its all hooked up,wires are correct and it doesnt seem to shift better at all. It still has the same Lazy shift. Does anyone know anything about these? or know what i might be doing wrong?
Old Oct 6, 2003 | 07:58 PM
You might do a search. You will find many warnings about using a Shiftplus and what it might do to your tranny. If you have it connected properly it should work, unless the unit is bad. Double check your work. Use a meter or test light to verify connections, if necessary.
Old Oct 6, 2003 | 08:59 PM
84z94z's Avatar
I installed the B&M Shiftplus kit on my 94Z a month ago and could'nt tell it was working due to the poor job it does at stiffening the shift. I thought it would be good to be able to turn off the stiffness, but I am very unhappy with the product.
ANDYZ28
Dec 29, 2014 09:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
RedLineRev
Jan 23, 2003 03:51 PM
Rich_z28
Aug 27, 2002 12:20 AM
DarkHorse
Aug 1, 2002 04:59 PM
