just bought a 95 z28 for a v6 swap what should i run thru and check
Old Mar 22, 2005 | 11:01 PM
gerard14's Avatar
I just bought a 95 z28 with 74k on it. runs good, but b4 i install it in my v6 car for my swap what should i check and go thru.
i plan to replace all gaskets and repair the dreaded intake leak. but what else?
any easy ways to check the crankshaft bearings,valves, etc
should i replace the timing chain?
thanks
Old Mar 22, 2005 | 11:37 PM
fade2blk500's Avatar
Re: just bought a 95 z28 for a v6 swap what should i run thru and check
thanks
If its only got 74k I wouldn't worry much about the bearings. If I were you I'd look into swapping in a cam/springs while the motors out and the intakes off. It'll be worth it.. Trust me
Old Mar 22, 2005 | 11:47 PM
gerard14's Avatar
I forgot to mention the motor does have a cam in it, but the info on it is lost. i have no idea what kind of cam or what mileage it was installed at.
i am gonna run my nitrous setup to. i'm not sure what to do here about this cam.
Deadbolt24
Dec 18, 2014 08:18 PM
cmdeshon
Dec 12, 2014 10:51 PM
pete53
Dec 9, 2014 07:31 AM
Bearmans
Dec 3, 2014 05:28 AM
Geoff Chadwick
Jul 31, 2002 12:07 PM
