Jet Hot Lt's Suck To Install
Old Jul 8, 2003 | 05:28 PM
1994TransAm's Avatar
hey guys,
i've spent 1 hour already trying to install the driverside header for JET HOT. the headers look great, but this insane!!!!!!!!
i've remove the valve cover, oil filter, oil cooler?
what will it take!!!!!!!!!!
Old Jul 8, 2003 | 05:36 PM
97bowtie's Avatar
Re: Jet Hot Lt's Suck To Install
Originally posted by 1994TransAm
hey guys,
I assume you have the steering knuckle removed? If so (assuming the Jet Hots are the same as the Hookers), the header should just slide in from the bottom.
Old Jul 9, 2003 | 08:04 AM
revtime's Avatar
I am beginning to think that my A4 tranny being out for a rebuild was a big reason I had it so easy installing my Hooker Jet Hots.
I took the steering linkage apart at the top and removed the oil filter and mine went right in. Both headers went in from the bottom and the passenger side needed the starter removed and it went right up in there.
Old Jul 9, 2003 | 09:23 AM
SWINGRRR's Avatar
Yeah, it sux no matter how you do it, but you open that cut-out for the first time.............ahhhh It dosen't get any better than that.
Old Jul 9, 2003 | 09:28 AM
Gripenfelter's Avatar
It went in pretty easy for my Hookers.
Just slid them in from under the car.
You have to get the car really high in the air.
Jet Hots shouldn't be much different.
You have to remove the oil filter, even for Mac shorties.
Old Jul 9, 2003 | 10:18 AM
Timberwolf's Avatar
Adam, did you see my 3 page long thread about my install progress? And they still aren't done. I have to go see if I can exchange the collectors because they won't clear the trans cross member. I sure as hell hope 2.5" exhaust clears it with rubbing and vibrating!!
Old Jul 9, 2003 | 11:04 AM
speed76demon's Avatar
Your going to have to do what i did and that is loosen the motor mount jack the engine up put a block on a jack and put it under the oil pan then raise it up and that header will go right in
Old Jul 9, 2003 | 11:52 AM
CamaroBoy96Z28's Avatar
I did the same. Took me 25 seconds to slide the driver's side up and didnt remove anything. Removed passanger side motor mount and loosened the driver's side motor mount, jacked up the engine a good 3.5" and slid the passanger side up effortlessly. I thought I had it hard but I guess I'm one of the lucky ones that my LT install went smoothly (for an LT1 anyway).
Old Jul 9, 2003 | 12:00 PM
anasazi's Avatar
eh, we removed my steering nuckel and.. um.. i think that was it. slid in from the bottom.
had to relocate the cruise control behind the metal heat shield protecting the brake lines though, and had to slightly bend the heat shield so that there is like a 1 - 2 mm gap between it and the header, no problems so far...
Nov 18, 2023 07:21 PM
jasonduaine
Mar 7, 2015 09:44 AM
LT14LIFE
Feb 9, 2015 09:35 PM
bandit383lt4
Dec 21, 2014 09:12 PM
GigaMp3z
Feb 20, 2003 02:57 PM
