Jet-Hot LT problems
Old Jun 29, 2004 | 10:02 AM
  #16
25th_Trans's Avatar
These are the only pics that I have, but it's not on the car.
Old Jun 29, 2004 | 12:28 PM
  #17
94NDTA's Avatar
I'll try to get some pics of mine. It looks like you have 2 bends in it. Are ALL the bolts on that side of the header bolted up? Did you jack the engine up with the stearing linkage still on the car? Does the shaft look bent or damaged at all?
Old Jun 29, 2004 | 12:35 PM
  #18
25th_Trans's Avatar
we took the steering linkage off before jacking the motor. The motor is lowered back down now. The shaft looks good, and the header bolts are all tight.
Old Jul 3, 2004 | 02:19 PM
  #19
25th_Trans's Avatar
found the problem, someone put a ls1 rack and pinion and steering linkage on it. now I have to find out what to do, either replace the rack and pinion and steering linkage or try to work something out with the #1 primary tube.
unless someone else has a better idea.
Old Jul 3, 2004 | 03:07 PM
  #20
Spinner's Avatar
That'll do it. LS1s dont have a rag joint and the shaft will interfere with lt1 headers
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
KASR_Z28
Aug 6, 2002 03:34 PM
ferraricameron
Jul 29, 2002 07:46 PM
