JET fan switch and SLP headers???
Old May 4, 2004 | 10:41 PM
the spindoctor's Avatar
it looks like the wires coming from the switch would be awefully close to the header tube. what would happen if they did get burned, would the fans not come on at all, an ses light, anything?
Old May 4, 2004 | 10:53 PM
Fuels94TA's Avatar
Yes it will not work, due too a broken wire. There is another way to install that sensor without breaking a sweat. I got this from another board member. Add in a brass t-fitting with the sensor and install it on the steam return lines from the cyl. head (passenger side). Connect all wires up. Then connect a ground wire off the t-fitting so the sensor will work. I have done this and very happy with the results.
Vinny
Edit: If you want to see were the sensor is at look at my web page for the engine pic and it's in front of the alt.
Old May 4, 2004 | 11:35 PM
thanks a lot, that sounds like a good idea. i'm glad i didn't try to put it in yet.
Old May 4, 2004 | 11:48 PM
Bud M's Avatar
The wire comes up between the pipes with plenty of room on my car
pic
Rich_z28
Sep 13, 2002 03:35 PM
Rich_z28
Sep 8, 2002 12:00 AM
Rich_z28
Aug 29, 2002 11:01 PM
Rich_z28
Aug 29, 2002 10:44 PM
Rich_z28
Aug 27, 2002 12:20 AM
