Jesel Kss Vs Kcs Shaft Mounted Rockers
I talked to Joe at Jesel and he said that the SS shaft mounted rockers were not strong enough for nitrous assisted engines. He suggested using the next step up which is the CS shaft mounted rockers, which is a much stronger alloy than the SS uses. He said the cylinder pressure against the exhaust valve with nitrous, blower or turbo will cause failure. Anyone agree or disagree or have any suggestions? I will be buying a set soon and don't want to make a decision based on prices. Need help! Thanks for any input.
I have 383 11.8:1 , lt4 afr 210, solid cam/lifters, 250 shot, 4,000 stall Yank.
Call here:http:http://www.dreracing.com/
They build rockers for Comp also.
so what broke the nose off? jesel claims they are ok up to 800psi spring pressure and list nothing on the website that says anything on what kind of aspiration they will work on.
It had 400# on the seat.....They didn't seem suprized it broke
t&d and jesel both use 2024 aluminum for the rockers.
Victor Lamb
Aug 26, 2017 02:52 PM
