Opti Got A Tad Wet
Old Mar 31, 2008 | 04:20 PM
MarcR94v6's Avatar
Opti Got A Tad Wet
There were tiny drips of coolant from a hose by the TB on my new motor, drove it like this for probably 2-1/2 days, sometimes misfired, even backfired under load, during/before downshifting. It was also leaking onto my belt causing a killer squeak on startup. Just got it fixed by the engine builder, missed on the way home. Obviously it's not completely dry yet but did this cause any permanent damage? I thought that the optispark was a little more resilient to moisture than many would have you believe, am I wrong? Should I be worried?
Old Mar 31, 2008 | 04:24 PM
dangalla's Avatar
technically there is no way for water/coolant to get in there, they are sealed. i would think you may have gotten the wires wet and that is your problem. just run it and see if it clears up
Old Mar 31, 2008 | 04:55 PM
wrd1972's Avatar
What dangalla said. I think more people experience wet and or worn wires more often than wet optis.
Old Mar 31, 2008 | 06:06 PM
MarcR94v6's Avatar
Thanks guys.
Old Mar 31, 2008 | 09:58 PM
brianswimmer23's Avatar
just to throw my 2 cents they also could just go bad! mine went bad after 4000 miles dont know why but thank god it was under that 12000 mile warranty!
Old Mar 31, 2008 | 11:05 PM
https://www.camaroz28.com/forums/sho...d.php?t=593732
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
