Jesel Kss Vs Kcs Shaft Mounted Rockers
Old Mar 31, 2008 | 08:51 AM
LT4BLAZER's Avatar
I talked to Joe at Jesel and he said that the SS shaft mounted rockers were not strong enough for nitrous assisted engines. He suggested using the next step up which is the CS shaft mounted rockers, which is a much stronger alloy than the SS uses. He said the cylinder pressure against the exhaust valve with nitrous, blower or turbo will cause failure. Anyone agree or disagree or have any suggestions? I will be buying a set soon and don't want to make a decision based on prices. Need help! Thanks for any input.
I have 383 11.8:1 , lt4 afr 210, solid cam/lifters, 250 shot, 4,000 stall Yank.
Old Mar 31, 2008 | 08:54 AM
mdacton's Avatar
I've seen a few jesels bust the end/nose off.
I still have stud rockers but I think I'm going with T&D, they also have some better features...pressure oiling, but they are way more expensive
Old Mar 31, 2008 | 10:29 AM
LT4BLAZER's Avatar
Don't the heads have to be machined down .125 for the pedastal to mount to on the T&D setup?
Old Mar 31, 2008 | 06:28 PM
1racerdude's Avatar
Call here:http:http://www.dreracing.com/
They build rockers for Comp also.
Old Mar 31, 2008 | 07:36 PM
slammed98gmc's Avatar
so what broke the nose off? jesel claims they are ok up to 800psi spring pressure and list nothing on the website that says anything on what kind of aspiration they will work on.
Old Mar 31, 2008 | 07:39 PM
mdacton's Avatar
I don't know....It was a SBF W motor with a 400 shot on it. It busted the nose off halfway where the axle goes thru it.
It had 400# on the seat.....They didn't seem suprized it broke
Old Mar 31, 2008 | 07:46 PM
400 on the seat is a nasty spring. We are only trying to run 225 on the seat and 500-550 open with 250 shot of nitrous.
t&d and jesel both use 2024 aluminum for the rockers.
Old Mar 31, 2008 | 10:13 PM
fast 93 z's Avatar
I am running Jesels with 200 seat and 800 open.
No problems here.
Victor Lamb
Aug 26, 2017 02:52 PM
HectorM52
Jul 30, 2017 11:46 AM
HarleyZ28
Oct 5, 2015 06:23 AM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
