I've been reading that a lot of Pacesetter LT guys have y pipe problems......
Old Jul 23, 2006 | 09:06 PM
  #16
jdhommert's Avatar
Re: I've been reading that a lot of Pacesetter LT guys have y pipe problems......
I had prothane poly mounts put in when i had my headers in, and they don't bang at all.
Old Jul 24, 2006 | 04:02 AM
  #17
Sinister95Z's Avatar
Not a single fit issue here either. I did the headers, y-pipe, poly motor mounts and a poly tranny mount all at the same time. I could not be happier with how well everything fit together.
Old Jul 24, 2006 | 06:15 AM
  #18
J Rod's Avatar
No problems here as far as hitting the floorboard. Although I did have some leaks at the collector/y-pipe connections but I fixed that by welding up the driver's side and installing a ball flange on the pass. side. I would've done a ball flange at the driver's side as well but it wouldn't fit with that stupid hump there. I definitely would've had some banging issues if I had done that. I couldn't be happier with the way it came out though, sounds awesome with my magnaflow.
Old Jul 24, 2006 | 07:49 AM
  #19
1quickTA's Avatar
Mine is fine at idle and normal driving and even harder shift, but if I am flying at WOT and am really banging through the gears it does hit the floor.
Old Jul 24, 2006 | 08:12 PM
  #20
GreenZLT1's Avatar
mine used to be real bad at first. It would bang at idle, WOT, anywhere. I took some jack thing my dad had and put it between the y-pipe and floor brace and bent the header down. It didn't even dent the floor or pipe! Now I only get a little bang bang when I get on it really hard.
Rob
Old Jul 24, 2006 | 11:24 PM
  #21
I burn rice too's Avatar
Mine only hit when I'm at WOT. I just deal with it. It's really not that bad. I'm hoping that SFC's fix that problem. Or that's what I'm going to tell my wife.
spearous
Jan 12, 2015 11:03 AM
Red97LT1
Aug 7, 2002 05:45 PM
